Arduino MKR IoT Carrier Rev2 to Rev1 pin assignment change?
Hello, I encountered an issue in compatibility with the UART port on the MKR1010 Wi-fi because the current revision of the Arudino MKR Wi-Fi IoT carrier had changed the pins of the relays from 14 and 13 to 1 and 2. This causes issues in repurposing them for serial port use and I was wondering if there's either a way to revert the revision of the Arduino carrier or manipulate the pins in a way that can erase compatibility issues. This would be incredibly beneficial as the rev1 carrier is no longer available on the market.
Thank you so much.
