Arduino MKR WAN 1300 LoRa Private Network
Hi, it all arrived and I installed and configured LoRaServer OS Full using ic880A-SPI.
Now I'm trying to transmit data with Arduino MKR WAN 1300 using the Sketch "First Configuration", opening the Serial Monitor tells me:
"Welcome to MKRWAN1300 first configuration sketch
Register to your favorite LoRa network and we are ready to go!
Your module version is: ARD-078 1.1.9
Your device EUI is: a8610a3432237405
Are you connecting via OTAA (1) or ABP (2)? "-> I select" 1 "
And he says: "Enter your APP EUI" -> I enter 0000000000000000 as suggested by @brocaar in the article Where do I set the AppEUI? - #14 by devboy00 - ChirpStack Application Server - ChirpStack Community Forum
Then he asks me "Enter your APP KEY" I entered the application Key in the MBS format "30 e8 0e 74 b7 4c fd 41 f5 57 ff a5 e9 dc 0c 57" but says nothing then I tried with LSB but nothing.
So I tried to add "0x" to each segment and I entered "0x30 0xe8 0x0e 0x74 0xb7 0x4c 0xfd 0x41 0xf5 0x57 0xff 0xa5 0xe9 0xdc 0x0c 0x57" in MBS format but Arduino goes to Tilt and crashes.
I DO NOT UNDERSTAND WHAT I MUST DO!
On the internet I did not find any guide that connected Arduino MKR WAN 1300 to LoraServer.
Help me please!
abinformatica:
You would think that either Arduino (the company, not this forum) or LoRaServer would write one ..........
Would you say that they have created a card that nobody uses and for this reason there are not enough documentation?
