Hi everyone,
I was hoping to use the Arduino PMIC library (GitHub - arduino-libraries/Arduino_BQ24195: [Beta] Arduino library to control TI BQ24195 PMIC on compatible MKR boards) in order to check whether the MKRWAN 1310 was connected to a power supply. The function (USBmode()) seemed promising but is only returning 0 independent on whether a USB power supply or a power supply on the 5V input was used.
This does not seem correct to me. Any idea how to fix the issue (please see my code here below)?
#include <Arduino_PMIC.h>
while (!Serial);
if (!PMIC.begin()) {
Serial.println("Failed to initialize PMIC!");
while (1);
PMIC.enableDPDM();
int chargeCheck = PMIC.chargeStatus();
int chargeGood = PMIC.canRunOnBattery();
int powerCheck = PMIC.USBmode();
if (!PMIC.enableCharge()) {
Serial.println("Error enabling Charge mode");
Serial.print("Power: ");
Serial.print(powerCheck,HEX);
Serial.print(" Battery charge status: ");
Serial.print(chargeCheck,HEX);
Serial.print(" Can run on battery: ");
Serial.println(chargeGood,HEX);
Thanks a lot in advance,
