Arduino MKR Wifi 1010 Serial Communication with Arduino Mega
I am writing a serial communication program between a mkr wifi 1010 and a mega in which the mkr sends either a H or L char to the mega, and the mega responds by reading the char and setting it's onboard LED to either high or low depending on the char. When I use delay(#) on the mkr the code works just fine and the mega's LED blinks on and off.
However when I create delay-less code the mega's led will not blink. It either stays low or stays high, most of the time stays low. I have checked the mkr code by reading the serial port and it indeed sends 72(H) and 76(L) alternately at the correct interval in both versions of the code.
Wiring diagram:
MKR          Mega
gnd    ->     gnd
tx     ->     rx
rx     ->     tx
I have level shifted the mega's tx pin down to 3.3v before the mkr's rx pin.
mkr delay code:
  uint32_t baudRate = 9600;
  Serial1.begin(baudRate);
  Serial1.print('H');
  Serial1.print('L');
mkr delay-less code:
unsigned long curT = 0;
unsigned long prevT = 0;
const int interval = 500;
int byteToSend = 'L';
  curT = millis();
  if (curT - prevT > interval)
    if (byteToSend == 'L')
      byteToSend = 'H';
      byteToSend = 'L';
    Serial1.print(byteToSend);
    prevT = curT;
mega code:
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
  // initialize serial communication:
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // see if there's incoming serial data:
  if (Serial.available() > 0)
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
    // if it's a capital H (ASCII 72), turn on the LED:
    if (incomingByte == 'H')
      digitalWrite(ledPin, HIGH);
    // if it's an L (ASCII 76) turn off the LED:
    if (incomingByte == 'L')
As far as I know these 2 different mkr programs do exactly the same thing and send serial data in the exact same way, it's just that one is blocking and one is non-blocking. Why is it that the delay-less code does not blink?
In the second sketch you used the wrong data type. If you change
to
char byteToSend = 'L';
your code should work as expected.
Thank you that fixed the issue.
