ARDUINO MKR WiFi D to A converter project
I want to use the MKR WiFi 1010 utilizing the D to A converter and internal counter. I can use help setting up the device configuration to use the D to A.
looking at analogWrite() documentation it states
In addition to PWM capabilities on the pins noted above, the MKR, Nano 33 IoT, and Zero boards have true analog output when using analogWrite() on the DAC0 (A0) pin.
also applies to the MKR1000 WiFi - should also appy to MKR1010 WiFi
