I have been trying to get an external MircoSD card module to work with my Arduino MKR ZERO. I tried changing the SD library SPI pins based on this .
I changed the variant.h from this:
// Needed for SD library
#define SDCARD_SPI SPI1
#define SDCARD_MISO_PIN PIN_SPI1_MISO
#define SDCARD_MOSI_PIN PIN_SPI1_MOSI
#define SDCARD_SCK_PIN PIN_SPI1_SCK
#define SDCARD_SS_PIN PIN_SPI1_SS
To this:
#define SDCARD_MISO_PIN PIN_SPI_MISO
#define SDCARD_MOSI_PIN PIN_SPI_MOSI
#define SDCARD_SCK_PIN PIN_SPI_SCK
#define SDCARD_SS_PIN PIN_SPI_SS
and it didn't work no matter what I tried. I always get initialization failed.
Juraj
June 6, 2021, 1:23pm
2
only comment out the SDCARD_ defines from variant.h
Commenting them out doesn't help, I still get the initialization failed.
Juraj
June 6, 2021, 3:09pm
4
then the problem is somewhere else
Do you have any idea what could it be then ? I haven't changed anything anywhere else beside this and startup file where I defined CRYSTALLESS. I'm using it without the external 32.768 Khz crystal and It runs any other program just fine.
Juraj
June 7, 2021, 5:02am
6
it is a custom board? try it first with normal MKR Zero. there are enough problems with SD card wiring to an established board
system
Closed
October 5, 2021, 5:02am
7
