Arduino mkr1000 and Mpu6050
Hi every one !
I have a problem with my arduino mkr1000. Before, I user an arduino uno for my project. Everything was fine exempt that the uno was not that powerful... So I switch on a mkr1000.
First, I don't know why, but the board never display "Serial.print" when they are in the "void setup()" function
Exemple :
  Serial.print("test");
Don't do anything
Then, I 've got the error Fifo Overflow every 10/15 line. This error never happen with my Uno, ans the mkr1000 ils much much much better than the Uno...
I décide to follow this tutorial : FIFO Overflow - MPU-6050 6-axis accelerometer/gyroscope (InvenSense) - I2Cdevlib Forums
But the first solution gave me the error "TWBR not declared in this scope"
The second solution doesn't do anything.
Last, during the compilation, I've got a lot of orange warning.
(Sorry for my bad Enflish and sorry for triple post, I have a limite of 9000 character.)
debugger result :
In file included from C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:42:0,
                 from C:\Users\quent\OneDrive\Documents\Arduino\Drone V1.2\DroneV1.2\DroneV1.2.ino:5:
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050/MPU6050.h:48:0: warning: "pgm_read_byte" redefined [enabled by default]
 #define pgm_read_byte(x) (*(x))
In file included from C:\Users\quent\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino/Arduino.h:36:0,
                 from sketch\DroneV1.2.ino.cpp:1:
C:\Users\quent\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino/avr/pgmspace.h:101:0: note: this is the location of the previous definition
 #define pgm_read_byte(addr) (*(const unsigned char *)(addr))
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050/MPU6050.h:49:0: warning: "pgm_read_word" redefined [enabled by default]
 #define pgm_read_word(x) (*(x))
C:\Users\quent\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino/avr/pgmspace.h:102:0: note: this is the location of the previous definition
 #define pgm_read_word(addr) (*(const unsigned short *)(addr))
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050/MPU6050.h:50:0: warning: "pgm_read_float" redefined [enabled by default]
 #define pgm_read_float(x) (*(x))
C:\Users\quent\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino/avr/pgmspace.h:104:0: note: this is the location of the previous definition
 #define pgm_read_float(addr) (*(const float *)(addr))
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050/MPU6050.h:51:0: warning: "PSTR" redefined [enabled by default]
 #define PSTR(STR) STR
C:\Users\quent\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino/avr/pgmspace.h:34:0: note: this is the location of the previous definition
 #define PSTR(str) (str)
C:\Users\quent\OneDrive\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:64:14: warning: #warning Using current Arduino IDE with Wire library is functionally limiting. [-Wcpp]
C:\Users\quent\OneDrive\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:65:14: warning: #warning Arduino IDE v1.0.1+ with I2CDEV_BUILTIN_FASTWIRE implementation is recommended. [-Wcpp]
C:\Users\quent\OneDrive\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:66:14: warning: #warning This I2Cdev implementation does not support: [-Wcpp]
C:\Users\quent\OneDrive\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:67:14: warning: #warning - Timeout detection (some Wire requests block forever) [-Wcpp]
In file included from C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.cpp:37:0:
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.h:48:0: warning: "pgm_read_byte" redefined [enabled by default]
                 from C:\Users\quent\OneDrive\Documents\Arduino\libraries\I2Cdev/I2Cdev.h:77,
                 from C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.h:40,
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.h:49:0: warning: "pgm_read_word" redefined [enabled by default]
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.h:50:0: warning: "pgm_read_float" redefined [enabled by default]
C:\Users\quent\OneDrive\Documents\Arduino\libraries\MPU6050\MPU6050.h:51:0: warning: "PSTR" redefined [enabled by default]
code :
#include <Wire.h>
#include <I2Cdev.h>
#include <Servo.h>
#include "MPU6050_6Axis_MotionApps20.h"
MPU6050 mpu;
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
int x = 0;
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
//define Kp,Ki,Kd
float kp[3], ki[3], kd[3];
//define PID variable (error, setpoint, mesure, error sum, error variation, last error and output)
float yprMesure[3], yprPidResult[3], yprOutput[3], yprError[3], yprAddError[3], yprVarError[3], yprLastError[3], yprSetpoint[3];
float rcControllerOutput[3];
float yprAngle[3];
//define ESC
Servo esc1;
Servo esc2;
Servo esc3;
Servo esc4;
    Wire.begin();
    // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // wait for ready
    Serial.println(F("\nSend any character to begin DMP programming and demo: "));
    while (Serial.available() && Serial.read()); // empty buffer
    while (!Serial.available());                 // wait for data
    while (Serial.available() && Serial.read()); // empty buffer again
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(166);
    mpu.setYGyroOffset(-79);
    mpu.setZGyroOffset(35);
    mpu.setZAccelOffset(1590);
    // make sure it worked (returns 0 if so)
    if (devStatus == 0) {
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    // configure LED for output
    pinMode(LED_PIN, OUTPUT);
    kp[0] = 10.0, kp[1] = 5.1, kp[2] = 4.5;
    ki[0] = 0.055, ki[1] = 0.048, ki[2] = 0.045;
    kd[0] = 18.0, kd[1] = 42, kd[2] = 50;
    //attach esc to the right pin
    esc3.attach(2);
    esc2.attach(3);
    esc1.attach(4);
    esc4.attach(5);
inline void gyroPidAxe(float yprMesure[], float yprOutput[], float yprSetpoint[], char n)
  //Compute error for all the 3 axis
  yprError[n] = yprSetpoint[n] - yprMesure[n];
  //Compute error sum for all the 3 axis
  yprAddError[n] += yprError[n];
  // Compute error variation for all the 3 axis
  yprVarError[n] += yprError[n] - yprLastError[n];
  //Compute angle correction
  yprOutput[n] = kp[n] * yprError[n] + ki[n] * yprAddError[n] + kd[n] * yprVarError[n];
  //Compute Last error
  yprLastError[n] = yprError[n];
void gyroPid(float yprMesure[], float yprOutput[], float yprSetpoint[])
  gyroPidAxe(yprMesure, yprOutput, yprSetpoint, 0);
  gyroPidAxe(yprMesure, yprOutput, yprSetpoint, 1);
  gyroPidAxe(yprMesure, yprOutput, yprSetpoint, 2);
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize) {
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    } else if (mpuIntStatus & 0x02) {
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        // display Euler angles in degrees
        mpu.dmpGetQuaternion(&q, fifoBuffer);
        mpu.dmpGetGravity(&gravity, &q);
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
        //Serial.print("ypr\t");
        yprAngle[0] = ypr[0] * 180/M_PI;
        yprAngle[1] = ypr[1] * 180/M_PI;
        yprAngle[2] = ypr[2] * 180/M_PI;
        //Call the fonction every seconds (for good correction, you need at least a delay of 20ms or faster)
        gyroPid(yprAngle, yprPidResult, rcControllerOutput);
        //Print the corrections values for each angle
        Serial.print(yprAngle[0]);
        Serial.print(" ");
        Serial.print(yprAngle[1]);
        Serial.print(" ");
        Serial.print(yprAngle[2]);
        Serial.print(" ");
        Serial.println(x);
        yprPidResult[0] = constrain(yprPidResult[0], -5000, 5000);
        yprPidResult[1] = constrain(yprPidResult[1], -5000, 5000);
        yprPidResult[2] = constrain(yprPidResult[2], -5000, 5000);
        yprPidResult[0] = map(yprPidResult[0], -5000, 5000, -200, 600);
        yprPidResult[1] = map(yprPidResult[1], -5000, 5000, -200, 600);
        yprPidResult[2] = map(yprPidResult[2], -5000, 5000, -200, 600);
        esc1.write(1500 + yprPidResult[0] - yprPidResult[1] - yprPidResult[2]);
        esc2.write(1500 - yprPidResult[0] + yprPidResult[1] - yprPidResult[2]);
        esc3.write(1500 - yprPidResult[0] - yprPidResult[1] - yprPidResult[2]);
        esc4.write(1500 + yprPidResult[0] + yprPidResult[1] + yprPidResult[2]);
        // blink LED to indicate activity
        blinkState = !blinkState;
        digitalWrite(LED_PIN, blinkState);
    x++;
The i2cdevlib is not for the mkr1000. Perhaps there is a "safe" setting for the i2cdevlib ?
The mrk1000 has a working serial port with some versions of the Arduino IDE, and not with other versions. I think there is a patch-file somewhere to make the mkr1000 work with the latest Arduino IDE.
Why is the Uno not powerful ? Some users think that the Uno is slow, but they have a sketch that uses delay() in many places, and we have to explain that the sketch will be just as slow on a faster processor.
If you want to connect a MPU-6050 to a mkr1000, wait a year.
Thanks for answer !
The Uno is too slow for the computation I need, that's not a question of delay :stuck_out_tongue:
I don't really understand what is a "safe" setting for the icdevlib ... Is it a version made for the mkr1000 ? or a setting in the library ?
EDIT : Problem quite solved : I have installed the last version of the I2Cdev and MPU6050 library, and all the warning dissapeared :smiley: The FIFO overflow was caused by my USB cable but I still research a patch for the Serial.write() bug. (something interesting is that the simple exemple I post don't work, like the old mpu6050 exemple, but the new one work ... strange)
