Arduino mkr1000 to drive a stepper driver
Hi guys,
I was wondering if I can drive a stepper driver using Arduino mkr1000.
I am afraid the 3V3 will not be enough.
I attached the expected voltage diagram for the driver.
It may be just enough but I don't want to risk it either.
Thank you.
The document says around 3.5V to be expected as digital signal.
Can I use 3.3V? Is this going to be enough do you think?
gkhn:
Post a link to the document you are referring to.
...R
Please find it here:
http://www.leadshine.com/UploadFile/Down/EMhm_V1.1.pdf
Thank you.
Robin2:
...R
I wonder is there another document that specifies the electrical characteristics - particularly the lowest signal voltage that is reliably considered to be HIGH.
I may have missed something but on the basis of what I have seen in the document you have linked to I would not be confident that a 3.3v microprocessor would be sufficient. Can you afford to try it and get a 5v Arduino if it does not work with the 3.3v one?
...R
Thank you.
I have an arduino uno which works perfectly.
I use advancedfirmata to generate signals for the driver.
I was planning to use mkr1000 so that I can use the device over wifi. That's the reason I am changing the arduino board.
Robin2:
...R
