Arduino MKR1010 USB Failure
Hey,
I was using an Arduino MKR1010 previously for a project that utilized the com port for serial monitor. And it happens so that my computer needed a reset and basically I had to reinstall the Arduino IDE and all the prerequisites that the MKR1010 needs.
Once I did that the board failed to show up on any COM ports and this is the case when I open up my manager:
Error: Unknows USB Device (Device Descriptor Request Failed)
Trying the double-tap the reset button to enter the bootloader also shows the same issue.
I do admit I am fairly new to this, am I missing something?
I have tried re-installing the FTDI drivers, re-installing using the boards manager in Arduino IDE. Anything else that I can do?
Hey guys quick update, running to the store and getting a new USB cable fixed the issue.
For some reason this cable has gone bad even though I have this same cable for previous projects.
For anyone with the same issue, try using another cable or two.
