I tried out this code. It seems to be sending the commands that I type in the serial monitor, to the sensor correctly, but not getting any readings from the sensor. Please let me know what might be the problem and what may be the changes to be made.
/-----( Import needed libraries )-----/
#include <SoftwareSerial.h>
/-----( Declare Constants and Pin Numbers )-----/
#define SSerialRX 10 //Serial Receive pin
#define SSerialTX 11 //Serial Transmit pin
#define SSerialTxControl 3 //RS485 Direction control
#define RS485Transmit HIGH
#define RS485Receive LOW
#define Pin13LED 13
/-----( Declare objects )-----/
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
/-----( Declare Variables )-----/
int byteReceived;
int dataReceived;
int byteSend;
// Start the built-in serial port, probably to Serial Monitor
Serial.println("YourDuino.com SoftwareSerial remote loop example");
Serial.println("Use Serial Monitor, type in upper window, ENTER");
pinMode(Pin13LED, OUTPUT);
pinMode(SSerialTxControl, OUTPUT);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
// Start the software serial port, to another device
RS485Serial.begin(9600); // set the data rate
digitalWrite(Pin13LED, HIGH); // Show activity
if (Serial.available())
byteReceived = Serial.read();
Serial.println(byteReceived);
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
RS485Serial.write(byteReceived); // Send byte to sensor
digitalWrite(Pin13LED, LOW); // Show activity
delay(10);
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit
if (RS485Serial.available()) //Look for data from the sensor
Serial.println("data available");
dataReceived = RS485Serial.read(); // Read received byte
Serial.write(dataReceived); // Show on Serial Monitor
delay(10);
