Arduino Modbus Digital pins not working
Hello,
Premise :
I am using Arduino-modbus library (GitHub - andresarmento/modbus-arduino: A library that allows your Arduino to communicate via Modbus protocol, acting as a slave (master in development). Supports serial (RS-232, RS-485) and IP via Ethernet (Modbus IP).) to use my Arduino device as a slave modbus. It is working fine.
Problem:
When i try to write to a Analog output Pin ( %QW0.0 which is pin No 9 in Arduino) using pymodbus, I can see the LED glowing.
But when i try to do the same to a Digital Output Pin ( %QX0.0 which is pin No 7 in Arduino ) using pymodbus the LED is not turning on. Cant seem to understand why.
Any help is appreciated.
Thanks in advance.
Premise :
Which of the five? And using what sketch?
