Arduino Modbus No matching Function
I am trying this library modbus Slave and whenever I compile it, it gives this error of :
no matching function for call to 'modbusSlave::setBaud(HardwareSerial*, int, int, int)'.
the code is
#include <ModbusRtu.h>
#include <modbus.h>
#include <modbusDevice.h>
#include <modbusRegBank.h>
#include <modbusSlave.h>
//modbusDevice regBank;
//Create the modbus slave protocol handler
modbusSlave slave;
int warnState = 1;
const int pinFour = 4;
const int pinTwo = 2;
#define RS485TxEnablePin 2
#define RS485Baud 9600
#define RS485Format SERIAL_8E1
  pinMode(pinFour,INPUT);
  pinMode(LED_BUILTIN,OUTPUT);
  pinMode(pinTwo,OUTPUT);
  //Assign the modbus device ID
  regBank.setId(2);
  //Add Analog Output registers to the register bank
  regBank.add(40001);
  regBank.add(40003);
  slave._device = &regBank;
  slave.setBaud(&Serial,RS485Baud,RS485Format,RS485TxEnablePin);
  Serial.flush();
}//end of void setup()
  Serial.flush();
  slave.run();
}//end if void loop()
so I defined the
and
when I compiled it, it gives me an error of
error: no matching function for call to 'modbusSlave::setBaud(HardwareSerial*, int, int, int)'
I am looking for any documentation regarding setBaud. pls help
I can't find the setBaud() function in the library
Where did you copy this line of code from ?
ModbusSlaveLib.zip (8.0 KB)
this is the library.
