Hi Everyone:
Hope you are all doing fine!
I come to you for your kind help and/or advice…
I’ve been working some time trying to get data out of a TUF-2000M ultrasonic Flow Meter with and arduino using the Modbus RTU protocol over RS485. So far I think I’m able to connect to the device accordingly but i can not make sense of the data I’m receiving back from it…
here is my code…
#include <SimpleModbusMaster.h>
/* To communicate with a slave you need to create a
packet that will contain all the information
required to communicate to that slave.
There are numerous counters for easy diagnostic.
These are variables already implemented in a
packet. You can set and clear these variables
as needed.
There are general modbus information counters:
requests - contains the total requests to a slave
successful_requests - contains the total successful requests
total_errors - contains the total errors as a sum
timeout - contains the total time out errors
incorrect_id_returned - contains the total incorrect id returned errors
incorrect_function_returned - contains the total incorrect function returned errors
incorrect_bytes_returned - contains the total incorrect bytes returned errors
checksum_failed - contains the total checksum failed errors
buffer_errors - contains the total buffer errors
And there are modbus specific exception counters:
illegal_function - contains the total illegal function errors
illegal_data_address - contains the total illegal data_address errors
illegal_data_value - contains the total illegal data value errors
misc_exceptions - contains the total miscellaneous returned exceptions
And finally there is a variable called “connection” that
at any given moment contains the current connection
status of the packet. If true then the connection is
active if false then communication will be stopped
on this packet untill the programmer sets the “connection”
variable to true explicitly. The reason for this is
because of the time out involved in modbus communication.
EACH faulty slave that’s not communicating will slow down
communication on the line with the time out value. E.g.
Using a time out of 1500ms, if you have 10 slaves and 9 of them
stops communicating the latency burden placed on communication
will be 1500ms * 9 = 13,5 seconds!!!
modbus_update() returns the previously scanned false connection.
You can use this as the index to your packet array to find out
if the connection has failed in that packet and then react to it.
You can then try to re-enable the connecion by setting the
packet->connection attribute to true.
The index will only be available for one loop cycle, after that
it’s cleared and ready to return the next false connection index
if there is one else it will return the packet array size indicating
everything is ok.
All the error checking, updating and communication multitasking
takes place in the background!
In general to communicate with to a slave using modbus
RTU you will request information using the specific
slave id, the function request, the starting address
and lastly the number of registers to request.
Function 3 and 16 are supported. In addition to
this broadcasting (id = 0) is supported on function 16.
Constants are provided for:
Function 3 - READ_HOLDING_REGISTERS
Function 16 - PRESET_MULTIPLE_REGISTERS
The example sketch will read a packet consisting
of 3 registers from address 0 using function 3 from
the GM7U LS Industrial PLC (id = 2) and then write
another packet containing the same 3 registers and
the counter information of both packets using function 16
to address 3 in the PLC. Using the supplied PLC software
you can then view in realtime what the values are in
the PLC’s registers.
// led to indicate that a communication error is present
#define connection_error_led 13
//////////////////// Port information ///////////////////
#define baud 9600
#define timeout 1000
#define polling 500 // the scan rate
// If the packets internal retry register matches
// the set retry count then communication is stopped
// on that packet. To re-enable the packet you must
// set the “connection” variable to true.
#define retry_count 10
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 4
// This is the easiest way to create new packets
// Add as many as you want. TOTAL_NO_OF_PACKETS
// is automatically updated.
enum
PACKET1,
//PACKET2,
// leave this last entry
TOTAL_NO_OF_PACKETS
// Create an array of Packets for modbus_update()
Packet packets[TOTAL_NO_OF_PACKETS];
// Create a packetPointer to access each packet
// individually. This is not required you can access
// the array explicitly. E.g. packets[PACKET1].id = 2;
// This does become tedious though…
packetPointer packet1 = &packets[PACKET1];
//packetPointer packet2 = &packets[PACKET2];
// The data from the PLC will be stored
// in the regs array
unsigned int regs[9];
// read 3 registers starting at address 0
packet1->id = 1;
packet1->function = READ_HOLDING_REGISTERS;
packet1->address = 138;
packet1->no_of_registers = 1;
packet1->register_array = regs;
/* // write the 9 registers to the PLC starting at address 3
packet2->id = 2;
packet2->function = PRESET_MULTIPLE_REGISTERS;
packet2->address = 3;
packet2->no_of_registers = 9;
packet2->register_array = regs;*/
// P.S. the register_array entries above can be different arrays
// Initialize communication settings etc…
modbus_configure(baud, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS);
pinMode(connection_error_led, OUTPUT);
unsigned int connection_status = modbus_update(packets);
if (connection_status != TOTAL_NO_OF_PACKETS)
digitalWrite(connection_error_led, HIGH);
// You could re-enable the connection by:
//packets[connection_status].connection = true;
digitalWrite(connection_error_led, LOW);
// update the array with the counter data
regs[3] = packet1->requests;
regs[4] = packet1->successful_requests;
regs[5] = packet1->total_errors;
/* regs[6] = packet2->requests;
regs[7] = packet2->successful_requests;
regs[8] = packet2->total_errors; */
Serial.print("Requests: ");
Serial.println(regs[3]);
Serial.print("Successful: ");
Serial.println(regs[4]);
Serial.print("Errors: ");
Serial.println(regs[5]);
Serial.print("data 1: ");
Serial.println(regs[0]);
Serial.print("data 2: ");
Serial.println(regs[1]);
Serial.print("data 3: ");
Serial.println(regs[2]);
Serial.print("data 4: ");
Serial.println(regs[6]);
Serial.println(regs[7]);
Serial.println(regs[8]);
Serial.println(regs[9]);
float temp = (long)regs[0] << 16 | regs[1];
Serial.println(temp);
float temp1 = (long)regs[1] << 16 | regs[0];
Serial.println(temp1);
and Here is the output i get…
Requests: 15
Successful: 14
Errors: 1
data 1: 31376
data 2: 0
data 3: 0
data 4: 0
0
0
769
31376
2056257536.00
31376.00
In this code I’m getting data out of register 138 that corresponds to total flow of the day… the value in the device is 2.8339 but i get in regs[0] 31376…
I’m pretty sure my data is somehow encoded in the regs[0] but i do not know the format of the information I’m receiving… maybe the 31376 is a decimal representation of a hexadecimal code or something…
the 769 is a value i always get no matter what register i get data from… so i guess that contains the address and funcion … (769 to hex is 0301 03 being the read registers function and 01 the id of the device… but i’m not sure…
So any light on how to get the data i’m looking for is very appreciated.
Thank you very much.
