Arduino Modbus TCB/IP (Connection to Easergy P3)
Hi everyone,
Hope you are doing well. I have a problem communicating with Easergy P3 Schneider device using Arduino to monitor the data on the serial of the Arduino. I am using Modbus TCP/IP communication protocol to have my job done. the setup is Arduino mega with W5100 Ethernet module connected to a router with the Easergy P3 device connected to the same router. Hope any one can help me.
Regards,
Modbus TCP Client Multiple for P1AM-100/P1AM-ETH
This sketch increments a register of a Modbus TCP server.
Multiple Clients can be created and maintained, but the Library
code is blocking. So all delays in communictions will delay the
main loop() execution.
This example uses Serial.print() to display status information.
The Serial Monitor must be running for the sketch to start.
Required Libraries which need to be installed.
GitHub - arduino-libraries/ArduinoModbus
GitHub - arduino-libraries/ArduinoRS485
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
byte mac[] = { //Use the Reserved MAC printed on the right-side label of your P1AM-ETH.
0x00, 0x1A, 0xD3, 0x40, 0x8A, 0x78
IPAddress ip(192, 168, 1, 1);//IP Address of the P1AM-ETH module.
int HR400001;
int HR400002;
EthernetClient clients[4];
ModbusTCPClient modbusTCPClient[4]={
ModbusTCPClient(clients[0]),
ModbusTCPClient(clients[1]),
ModbusTCPClient(clients[2]),
ModbusTCPClient(clients[3])
IPAddress servers[4]={//IP Addresses of the Servers
IPAddress(192, 168, 1, 1),
IPAddress(10, 11, 0, 23),
IPAddress(10, 11, 0, 24),
IPAddress(10, 11, 0, 25)
Ethernet.begin(mac, ip);
modbusTCPClient[0].setTimeout(500);//Adjust Response Timeout from 30 seconds to 500 ms.
// modbusTCPClient[1].setTimeout(500);//Adjust Response Timeout from 30 seconds to 500 ms.
Serial.begin(115200);// wait for serial port to connect.
while (!Serial) {};// wait for serial port to connect.
Serial.println("Modbus TCP Client Multiple Example");
Serial.print("P1AM-ETH at IP:");
Serial.println(ip);
Serial.println(modbusTCPClient[0].connected());
if (!modbusTCPClient[0].connected()) {// client not connected, start the Modbus TCP client
Serial.print("Attempting to connect to Modbus TCP server at IP:");
Serial.println(servers[0]);
if (!modbusTCPClient[0].begin(servers[0])) {
Serial.println("Modbus TCP Client failed to connect!");
Serial.println("Modbus TCP Client connected");
} else {// client connected
if (!modbusTCPClient[0].holdingRegisterWrite(0x00, HR400001++)) {
Serial.print("Failed to write! ");
Serial.println(modbusTCPClient[0].lastError());
// if (!modbusTCPClient[1].connected()) {// client not connected, start the Modbus TCP client
// Serial.print("Attempting to connect to Modbus TCP server at IP:");
// Serial.println(servers[1]);
// if (!modbusTCPClient[1].begin(servers[1])) {
// Serial.println("Modbus TCP Client failed to connect!");
// } else {
// Serial.println("Modbus TCP Client connected");
// } else {// client connected
// if (!modbusTCPClient[1].holdingRegisterWrite(0x01, HR400002--)) {
// Serial.print("Failed to write! ");
// Serial.println(modbusTCPClient[1].lastError());
You don't tell us what problem you have.
You shouldn't use the ArduinoModbus library on AVR Arduinos as it doesn't use RAM sparingly and AVR Arduinos doesn't have that much RAM. The Mega2560 has the most RAM of the family so it might work for quite some time before you run into troubles.
