Arduino + Mosfet + PSU = Standalone heated 3D print bed
Hello all,
My goal is to create a standalone heated 3D print bed using the following compenents,
Arduino Uno
MOFSET- https://www.amazon.com/gp/product/B078S6221G/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Anet heated bed -https://www.amazon.com/gp/product/B076V38M7R/ref=ppx_yo_dt_b_asin_title_o08_s01ie=UTF8&psc=1
Thermistor- https://www.amazon.com/gp/product/B07JGJKPT9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
The goal of this plate is to maintain a temperature of 50C.
Is this project feasible with these components and a PID algorithm?
If so, is there a simpler way to control the temperature through code without using and tuning a PID system?
Thanks for reading.
It appears it will work however I could not find the current required, voltages, MOSFET rating (it did not come up from your link).
Make life a little bit easier, consider this:
DS18B20 is 1-Wire interface Temperature sensor manufactured by Dallas Semiconductor Corp. … It can measure temperatures from -55°C to +125°C with ±0.5°C Accuracy. The resolution of the temperature sensor is user-configurable to 9, 10, 11, or 12 bits.
You can get a IRF520 MOSFET Driver Module for Arduino for about $0.75 on ebay.
You can get code to operate all of this on this web site, making it a lot easier for you.
Have Fun, Good Luck! Gil
Thank you for the reply, that helps a lot! I'm digging into it now. I really appreciate the suggestion, I hit that sweet karma button for you.
