I have an Arduino Motor Shield and I have an issue with the A0 pin.
I am reading a small amount of voltage at that pin. Even when the motor output is at 0.
I am also able to read a small amount of voltage there using analogRead. Even though the motor output voltage is 0.
voltage reading of between .099 and .104 volts. at 0 output to motor.
The change in voltage however is approximately equal to the current delivered to the motor I am running. I am dealing with a very low current motor, 60ma at max draw so my voltage change is small. I can measure the current to the motor on the output of the Motor Shield, do the calculation of voltage change on the A0 pin and those values are within a couple of ma. So the readings appear to be accurate.
Is there a possible issue with my Motor Shield, because I may have messed up that output while attempting another sketch not fully understanding that the A0 was dedicated to current sensing on the Motor Shield.
