Arduino motor shield R3 - Vin connect
Hi - it says on the Arduino motor shield page http://arduino.cc/en/Main/ArduinoMotorShieldR3to cut the Vin connect jumper if I want to decouple the Arduino and external power (which I do).
What exactly does that mean? All I see are two pads soldered together (or am I looking at the wrong thing) - how can I "cut the jumper"?
Thanks!
Vin on the screw terminal block, is the input voltage to the motor connected to the shield. An external power supply connected to this pin also provide power to the Arduino board on which is mounted. By cutting the "Vin Connect" jumper you make this a dedicated power line for the motor.
Since the two pads are soldered together, you should unsolder them. If you do not have access to a soldering iron, a last resort would be to cut away the connecting solder with a small tool, such as a file, or knife.
