Arduino motor shield rev3 first approach running a dc-motor (without a library)
​ hello dear experts good day dear Arduino-community,
well first of all - i want to express that i am very happy to be here at this great place - the true hotspot for all Arduino-thnigs at this great place the arduino-forum. (as it covers all arduino-question)
I have buyes a arduino motor shield rev3 (revision 3) see the page where it is being sold: https://store.arduino.cc/arduino-motor-shield-rev3 When I follow the link for "Getting Started section" the page lists a lot of shields but not the motor shield. I am looking for a library for the motor board - or at least for an first approach to get the thing up and running.
What is aimed: I'm trying to drive 2 DC motors - for a rc-car. Therefore i have connected two DC Servo Motors to the Motor Shield and wrote the following sequence:
      //Setup Channel A
      pinMode(12, OUTPUT);     //Initiates Motor Channel A pin
      pinMode(9, OUTPUT);      //Initiates Brake Channel A pin
      //Setup Channel B
      pinMode(13, OUTPUT);     //Initiates Motor Channel A pin
      pinMode(8, OUTPUT);      //Initiates Brake Channel A pin
... and afterwards:
      //Phase 1 - going to the wall
      //Motor A forward - Max Speed
      digitalWrite(12, LOW);   //this should try to establishes forward direction of Channel A
      digitalWrite(9, LOW);    //this is for the Disengage of the Brake for Channel A
      analogWrite(3, 255);     //this should help to spin the motor on Channel A at max speed
      //Motor B forward - Max Speed
      digitalWrite(13, HIGH);  //this is to establish forward direction of Channel B
      digitalWrite(8, LOW);    //this should help to disengage the brake for Channel B
      analogWrite(11, 255);    //this spins the motor on channel B at max speed
      delay(4000); // Adjust to correspond the distance
  //Phase 2 - getting back to initial point
  //Motor A backward - max speed
  digitalWrite(12, HIGH);  // this should establish backward direction of Channel A
  digitalWrite(9, LOW);    //now we need to disengage the Brake for Channel A
  analogWrite(3, 255);     //at this point i want to spins the motor on Channel A at max speed
  //Motor B backward - max speed
  digitalWrite(13, LOW);   // right now i try to establishes backward direction of Channel B
  digitalWrite(8, LOW);    //and now we want to disengage the Brake for Channel B
  analogWrite(11, 255);    //finally we want to spins the motor on Channel B at max speed
  delay(4000);
  //Phase 3 Stop for 7.5 seconds
  // Motor A stop
  digitalWrite(9, HIGH);   // here we try to engage the Brake for Channel A
    //Motor B
what happens now : While connected to USB, the device executes perfectly the sequence.
but wait: whein i run the sequence using the DC Source, the device does not respect any part of the coding. It started simply going forward while then it wante to reverse the polarity randomly blocking the movement sometimes.
i afterwards tried another approach as a library-replacement i have tried this code is simple enough:
  //Setup Channel A
void loop(){
  //forward @ full speed
  digitalWrite(12, HIGH); //Establishes forward direction of Channel A
  digitalWrite(9, LOW);   //Disengage the Brake for Channel A
  analogWrite(3, 255);   //Spins the motor on Channel A at full speed
  delay(3000);
  digitalWrite(9, HIGH); //Engage the Brake for Channel A
conclusio: Well - what is very very funny - with the second code-example it runs like a charme.
Looking forward to your suggestions.
yours apollodriver ​
If both motors run while connected to USB but the exact same sketch does not run when connected to your battery, that means your battery is not supplying enough current to drive both motors. What are you using as a battery?
It is also more helpful to post your complete sketch rather than snippets of setup() and later parts.
