Arduino Motor shield with high amperage power supply (30A)
Hi all
Is it possible to directly connect a 12V power supply delivering 30A to an Arduino Motor shield?
We want to pilot 2 different 12V motors 2A each that will be managed by the motor shield.
Second question:
What happens if the Vin and Gnd are inverted on this motor shield (GNd being connected to the + 12V)?
I'm asking this because a group of newbees did it recently and I think they burnt the motor shield. There was some burnt smell around and the card seems to be dead.
I will check its health next week but I'm not confident at all... I think that some capacitors burnt there...
thanks for your comments
The larger capacity supply can be used, the board/motor will only draw the current that is needed.
Reversing power/Gnd often damages parts permanently.
Which motor shield? Schematics are often available online, they can be checked to see if any reverse polarity protection was added. Sound like not in this case.
I don't see any reverse polarity protection here
so the board is probably shot, with more than just bad caps.
With supplies like that 30A and you only using 4A, put a 5A fuse in line before you zap something else.
Does the power supply have adjustable current limit?
Tom... :slight_smile:
Thanks CrossRoads
this is exactly that card that we are using
I don't see either any protection... I'm suspecting some capacitors to be dead now... :frowning:
TomGeorge, the fuse is a good idea. where do we put it? on the positive or negative wire? should be on the positive wire for me...
The power supply is very basic and just delivers 12V; That's all.
https://www.amazon.fr/SODIAL-Convertisseur-commutation-dalimentation-flexible/dp/B00DSG549K/ref=sr_1_57?s=electronics&ie=UTF8&qid=1479663961&sr=1-57&keywords=alimentation+12v
To have voltages to power the Arduino and the different steppers, we want to convert the 12V to 6V and 5V by using these cards
https://www.amazon.fr/HobbyKing-Turnigy-Voltage-Buzzer-Booole/dp/B01EE0VGA4/ref=sr_1_10?s=toys&ie=UTF8&qid=1479669888&sr=1-10&keywords=ubec
or this one
do you have any comments?
