Arduino motor switching. NEED HELP!
I am trying to make upa code where I can control a small motor with chip that act as a mosfet that I got from ebay.
I got this code to control one int in one way with a pot.
const int transistorPin = 9;    // connected to the base of the transistor
   // set  the transistor pin as output:
   pinMode(transistorPin, OUTPUT);
   // read the potentiometer:
   int sensorValue = analogRead(A0);
   // map the sensor value to a range from 0 - 255:
   int outputValue = map(sensorValue, 0, 1023, 0, 255);
   // use that to control the transistor:
   analogWrite(transistorPin, outputValue);
That one work rather well, but when I tried to make the next one.
float pressLength_milliSeconds =0;
int optionOne_milliSeconds = 100;
int optionTwo_milliSeconds = 2000;
int transistorPin0 = 9;    // connected to the base of the transistor
int transistorPin1 = 8;
int buttonPin = 2;
  pinMode(buttonPin, INPUT_PULLUP);
   pinMode(transistorPin0, OUTPUT);
   pinMode(transistorPin1, OUTPUT);
   Serial.begin (9600);
  while (digitalRead(buttonPin) ==LOW){
     delay(100);
     pressLength_milliSeconds = pressLength_milliSeconds + 100;
     Serial.print("ms = ");
Serial.println(pressLength_milliSeconds);
  if (pressLength_milliSeconds >= optionTwo_milliSeconds){
   analogWrite(transistorPin0, outputValue);
 else if(pressLength_milliSeconds >= optionOne_milliSeconds){
   analogWrite(transistorPin1, outputValue);
  pressLength_milliSeconds = 0;
It compiles flawlessly, however it does nothing in action. Can some one point out what I did wrong and help me adjust the code. :o :confused:
