Arduino MQTT doen't subcribe unless i restart mqtt server
Hi .
I am using esp8266 01 and NodeMCU 1.0. I saw that if I restart my Arduino device,with my mqtt server running,arduinos cant subscribe to topics in order to receive command. If I restart my mqtt server although they do it.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = “David”;
const char* password = “hh6945441201”;
const char* mqtt_server = “192.168.1.3”;
WiFiClient espClient;
PubSubClient client(espClient);
byte willQoS = 0;
const char* willTopic = “tele/esp/LWT/3”;
const char* willMessage = “Offline”;
boolean willRetain = true;
int mess = 9;
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print(“Connecting to “);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(”.”);
randomSeed(micros());
Serial.println("");
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.println("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload*);*
  • if (length - i == 1) {*
    _ mess = payload - 48;_
    * Serial.println();*
    void reconnect() {
    * // Loop until we’re reconnected*
    * while (!client.connected()) {*
    * Serial.println(“Attempting MQTT connection…”);*
    * // Create a random client ID*
    * String clientId = “David_ESP_3”;
    if (client.connect(clientId.c_str())) {
    _
    Serial.println(“connected”);_
    _
    client.publish(“tele/esp/LWT/3”, “Online”);_
    _
    client.subscribe(“cmnd/esp/power/3”);_
    _
    } else {_
    _
    delay(1000);_
    _
    Serial.print(“failed, rc=”);_
    _
    Serial.print(client.state());_
    _
    Serial.println(" try again in 5 seconds");_
    _
    // Wait 5 seconds before retrying*_
    * delay(6000);*
    * Serial.begin(115200);*
    * setup_wifi();
    client.setServer(mqtt_server, 1883);
    _
    client.setCallback(callback);_
    client.connect(“David_ESP_3”, willTopic, willQoS, willRetain, willMessage);
    _
    Serial.println(“System_ESP_3”);
    _
    //pinMode(2,OUTPUT); relay*_
    * if (!client.connected()) {*
    * reconnect();*
    * client.loop();*
    * if (mess == 1) {*
    * //digitalWrite(2,HIGH);*
    * client.publish (“stat/esp/power/3”, “ON”);*
    * mess = 9;*
    * else if (mess == 2) {*
    * //digitalWrite(2, LOW);*
    * client.publish (“stat/esp/power/3”, “OFF”);*
    * mess = 9;*
    * delay(500);*
    * Serial.println(“OK loop”);*
    [/quote]
    this is my code for esp8266 01 and I plan to put a relay.
    I don’t know if I writing wrong my code or if is mqtt configuration problem.
Each MQTT client must connect using a different client name.
 client.connect("David_ESP_3", willTopic, willQoS, willRetain, willMessage);
See this program for an example on generating unique mqtt client names.
thnx my friend.
ok I see what do you thing but when I flash the software I change it each time...David_esp_1, David_esp_2...... :frowning:
Hmm, I would try turning on debug messages on the MQTT broker/server side to see if it is rejecting connections and why.
Ok . I don’t know how to do this . I run my mqtt server through cmd command …
I found your script and used it for my own project. So I would like to share the solution with the comunnity.
You have a multiple client.connect into your code.
the line:
has to change to something like:
(client.connect("arduinoClient", willTopic, willQoS, willRetain, willMessage)) {
and remove the other line's from the void setup
  client.publish("tele/esp/LWT/3", "Online");
