arduino + MT8870
I found the attached code online for someone who has already started playing around with DTMF. The code gets me started. I haven't programed much but was able to follow what was going on in the code more or less.
I have built a circuit to decode the DTMF signals properly and the hardware is working 100%. I want to be able to monitor the dialpad number pressed on my phone in the serial monitor. The thing is I am getting sporadic errors. I know the hardware works because I have LEDs built into the circuit to display the dialpad number in binary and they light up properly. This is what the serial monitor looks like when I go through the dialpad
Key : 1
Key : 1
Key : 3
Key : 4
Key : 5
Key : 1
Key : 1
Key : 8
Key : 1
Key : 1
Key : 0
Key : 1
what i should be getting is
Key : 1
Key : 2
Key : 3
Key : 4
Key : 5
Key : 6
Key : 7
Key : 8
Key : 9
Key : *
Key : 0
Key : #
its like it defaulting to Key : 1 here and there. I have messed with the delay() function and that has made it better but its still random here and there.
Does anyone have any clue what might be causing this and also maybe a way to make the code a little more simple?
Thanks your help is greatly appreciated. This isn't for a school project. Just a hobby of mine
-Dan
#define stD_PIN  2   // stD Port, verifies a valid DTMF tone
#define D0_PIN   3   // Binary Data Port 0
#define D1_PIN   4   // Binary Data Port 1
#define D2_PIN   5   // Binary Data Port 2
#define D3_PIN   6   // Binary Data Port 3
byte stD_state;
 // Configures Serial Port @ 9600,8,N,1
 // Configure PIN mode
 pinMode(stD_PIN, INPUT);
 pinMode(D0_PIN, INPUT);
 pinMode(D1_PIN, INPUT);
 pinMode(D2_PIN, INPUT);
 pinMode(D3_PIN, INPUT);
 // Checks for valid tone
 stD_state = digitalRead(stD_PIN);
 if (stD_state == 1)
      Serial.print("Key : ");
      char key = read_code(); // Reads DTMF code
      Serial.println(key); // Prints the key received
      delay(350);          // Pause to syncronize the signal
byte read_code()
 byte data;           // Variable Que Tiene El Valor byte De La tecla
 char key;            // Variable Que Tiene El Valor Char  tecla
 byte D0,D1,D2,D3;    // Variable Donde Se Lee el Estado
 // Determines if D0...D3 is (1 or 0 , ON orOFF )
 D0 = digitalRead(D0_PIN);
 D1 = digitalRead(D1_PIN);
 D2 = digitalRead(D2_PIN);
 D3 = digitalRead(D3_PIN);
 // Covierte De Binario A BYTE o ENTERO
 // Escribe Los BITS En Una Variable dato
 bitWrite(data,0,D0);
 bitWrite(data,1,D1);
 bitWrite(data,2,D2);
 bitWrite(data,3,D3);
// Converts the key to CHAR
 if (data == 1) key = '1';
 if (data == 2) key = '2';
 if (data == 3) key = '3';
 if (data == 4) key = '4';
 if (data == 5) key = '5';
 if (data == 6) key = '6';
 if (data == 7) key = '7';
 if (data == 8) key = '8';
 if (data == 9) key = '9';
 if (data == 10) key = '0';
 if (data == 11) key = '*';
 if (data == 12) key = '#';
return key;
HI AVIATOR IF YOU WANT TO MAKE THE CODE SIMPLER WHT DONT USE DIGITAL READ AN IF AND ELSE
it is an 8870 chip. yeah as far as the timing goes i have varied the delay time everywhere from 80ms which causes doubles or triples to be displayed as well as time all the way up to 5 sec. 350ms is where the happy medium seemed to be where i wouldn't get repeats and didn't have to wait forever for the serial monitor to display the value.
So it has to be something to do with the code. Just messing around I placed
key = 0;
after the delay hoping that it might reset "key" every iteration of the loop but that seemed to only help it some. I still get false readings of "1" about 25% of the time.
