I found the attached code online for someone who has already started playing around with DTMF. The code gets me started. I haven't programed much but was able to follow what was going on in the code more or less.
I have built a circuit to decode the DTMF signals properly and the hardware is working 100%. I want to be able to monitor the dialpad number pressed on my phone in the serial monitor. The thing is I am getting sporadic errors. I know the hardware works because I have LEDs built into the circuit to display the dialpad number in binary and they light up properly. This is what the serial monitor looks like when I go through the dialpad
Key : 1
Key : 1
Key : 3
Key : 4
Key : 5
Key : 1
Key : 1
Key : 8
Key : 1
Key : 1
Key : 0
Key : 1
what i should be getting is
Key : 1
Key : 2
Key : 3
Key : 4
Key : 5
Key : 6
Key : 7
Key : 8
Key : 9
Key : *
Key : 0
Key : #
its like it defaulting to Key : 1 here and there. I have messed with the delay() function and that has made it better but its still random here and there.
Does anyone have any clue what might be causing this and also maybe a way to make the code a little more simple?
Thanks your help is greatly appreciated. This isn't for a school project. Just a hobby of mine
-Dan
#define stD_PIN 2 // stD Port, verifies a valid DTMF tone
#define D0_PIN 3 // Binary Data Port 0
#define D1_PIN 4 // Binary Data Port 1
#define D2_PIN 5 // Binary Data Port 2
#define D3_PIN 6 // Binary Data Port 3
byte stD_state;
// Configures Serial Port @ 9600,8,N,1
// Configure PIN mode
pinMode(stD_PIN, INPUT);
pinMode(D0_PIN, INPUT);
pinMode(D1_PIN, INPUT);
pinMode(D2_PIN, INPUT);
pinMode(D3_PIN, INPUT);
// Checks for valid tone
stD_state = digitalRead(stD_PIN);
if (stD_state == 1)
Serial.print("Key : ");
char key = read_code(); // Reads DTMF code
Serial.println(key); // Prints the key received
delay(350); // Pause to syncronize the signal
byte read_code()
byte data; // Variable Que Tiene El Valor byte De La tecla
char key; // Variable Que Tiene El Valor Char tecla
byte D0,D1,D2,D3; // Variable Donde Se Lee el Estado
// Determines if D0...D3 is (1 or 0 , ON orOFF )
D0 = digitalRead(D0_PIN);
D1 = digitalRead(D1_PIN);
D2 = digitalRead(D2_PIN);
D3 = digitalRead(D3_PIN);
// Covierte De Binario A BYTE o ENTERO
// Escribe Los BITS En Una Variable dato
bitWrite(data,0,D0);
bitWrite(data,1,D1);
bitWrite(data,2,D2);
bitWrite(data,3,D3);
// Converts the key to CHAR
if (data == 1) key = '1';
if (data == 2) key = '2';
if (data == 3) key = '3';
if (data == 4) key = '4';
if (data == 5) key = '5';
if (data == 6) key = '6';
if (data == 7) key = '7';
if (data == 8) key = '8';
if (data == 9) key = '9';
if (data == 10) key = '0';
if (data == 11) key = '*';
if (data == 12) key = '#';
return key;
