Hello everyone.
Apologies in advance for my bad level in English.
I'm looking for a way to use 3 wifi antennas on an Arduino Uno to create a bot following a mobile station emitting a continous signal.
I want to triangulate the station's position by mesuring the power on each antenna and tell the bot wich direction to go.
Is it possible to use the analog pin to mesure the signal's power without using the Tx and Rx pins ?
Isn't it possible to just detect one signal only by using analog/digital pins ?
If I'm right, the wifi is a digital signal. So we could detect the impulses from it on differents pins and compare the input we get. If the signal's emitter is futher of antenna A than antenna B, we should see stronger pulse on B than on the A.
You will not believe me, but you can forget any localization by radio emission (done from an UNO).
It is too slow, not sensitive enough, and has not enough resolution.
