Arduino multiple choice question game
Hello. Recently I got some lcd keypad shields and I have been thinking of making a game using the Arduino Mega 2560 and the shield.
Basically the LCD will display a question at the top, with some choices at the bottom. The user would select the answer using the left and right questions, then confirm their answer.
Right now I have been trying to do it on my own, by editing a sketch meant to test the keypad:
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
 adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
 if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.1 us this threshold
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 250)  return btnUP;
 if (adc_key_in < 450)  return btnDOWN;
 if (adc_key_in < 650)  return btnLEFT;
 if (adc_key_in < 850)  return btnSELECT;
 // For V1.0 comment the other threshold and use the one below:
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
 return btnNONE;  // when all others fail, return this...
{Serial.begin(115200);
 lcd.begin(16, 2);              // start the library
 lcd.setCursor(0,0);
 lcd.print("Push the buttons"); // print a simple message
 lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
 lcd.print(millis()/1000);      // display seconds elapsed since power-up
 lcd.setCursor(0,1);            // move to the begining of the second line
 lcd_key = read_LCD_buttons();  // read the buttons
 switch (lcd_key)               // depending on which button was pushed, we perform an action
   case btnRIGHT:
     lcd.print("RIGHT     ");
   case btnLEFT:
     lcd.print("LEFT     ");
   case btnUP:
     lcd.print("UP     ");
   case btnDOWN:
     lcd.print("DOWN     ");
   case btnSELECT:
     lcd.print("SELECT    ");
     case btnNONE:
     lcd.print("NONE    ");
I do not know how I would program responses to various outcomes (e.g how to know when the user selects the first choice, or the second choice). Does anyone know how I could do this?
Count the number of UPs, DOWNs, LEFTs and RIGHTs to see where the cursor is when SELECT is pressed.
