i have built a n mp3 player with arduino and a spark fun mp3 module plus an lcd to browse the songs the project is perfect but only play nine songs, can sny body suggest anypath i can take to increase the number of songs u can play or is the vs1053 having little memory
How are you storing the songs?
i am storing the songs on an sd card and the microcontrolller communicates to it using the spi interface and so does the 1053
You didn't say exactly what MP3 board you have (The VS1053 is the chip). If you have an SD card I assume it has enough memory for more songs, but you should know the size of the memory and the size of your files...
I assume the limitation is the lack of an operating system or a "proper" file system.
Can the Arduino directly read the MP3 files or anything from the SD card, or is it just directing/controlling the audio module?
I don't play the assume game. @talijackson please provided a detailed description of the issue you have encountered when you try to play more than 9 songs. If there are any error or warning messages, then post the full and exact text of them here.
Please post your full sketch.
- Auto Format your code by following these instructions:
- If using the Arduino IDE: select Tools > Auto Format from the menus.
- If using Arduino Cloud Editor: press Ctrl+B
- Click on the window that contains your sketch code.
- Press Ctrl+A. This will select all the text.
- Press Ctrl+C. This will copy the selected text to the clipboard.
- In a forum reply here, click on the reply field.
- Click the
icon on the post composer toolbar. This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V. This will paste the compilation output into the code block.
- Move the cursor outside of the code block markup before you add any additional text to your reply.
- Repeat the above process if your sketch has multiple tabs.
- Click the Reply button to post the output.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manager (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
hi ino i appreciate ur time but can u provide samwhere i can send the code so that u look at it
VS100X-based MP3 player
Plays mp3 files that must be in the SD formatted as FAT32
Uses a module based on a VS100X chip and a 20x4 LCD
#include <SPI.h>
#include <SD.h>
#include <AGMp3.h>
#include <LiquidCrystal.h>
// Pins for the lcd
#define LCD_RS 3
#define LCD_Enable 4
#define LCD_D4 A0
#define LCD_D5 A1
#define LCD_D6 A2
#define LCD_D7 A3
//Encoder pins
#define ENC_A 8
#define ENC_B 10
//Button pins
#define button_FORAWARD 0
#define button_BACK 1
// Minimum volume in db
#define MIN_VOL 60
// Maximum no of entries in a catalog
#define MAX_ENTRIES 15
// No of characters in each entry
#define MAX_LONG 20
#define MAX_LONGMAS1 21
// Defining characters for song progress
byte bar1[8] = { B10001, B10001, B10001, B10001, B10001, B10001, B10001, B10001 };
byte bar2[8] = { B11001, B11001, B11001, B11001, B11001, B11001, B11001, B11001 };
byte bar3[8] = { B11101, B11101, B11101, B11101, B11101, B11101, B11101, B11101 };
byte bar4[8] = { B11111, B11111, B11111, B11111, B11111, B11111, B11111, B11111 };
byte bar5[8] = { B11111, B11111, B11111, B11111, B11111, B11111, B11111, B11111 };
byte barV[8] = { B00001, B00001, B00001, B00001, B00001, B00001, B00001, B00001 };
// Initialiding liquid crystal display
LiquidCrystal lcd(LCD_RS, LCD_Enable, A0, A1, A2, A3);
//Creating object MP3
AGMp3Player MP3player;
//Catalog file
File fText;
char FileName[31];
byte temp;
byte result;
//Variab
char strArtist[MAX_LONGMAS1];
char strAlbum[MAX_LONGMAS1];
char strTitle[MAX_LONGMAS1];
// Variables to know the current and previous catalog entry, as well as the tenth of entries
byte Entry = 0;
byte Entry A = 0;
byte maxEntries = 0;
// Variables to control the encoder
byte posOn = 0;
byte encoderAon = LOW;
// Actual volume
byte vol = 20;
// Catalog of entries
char catalog[MAX_ENTRIES][MAX_LONGMAS1];
byte level, artist, album, track = 0;
char strLine [30];
void errorCard() {
lcd.setCursor(0, 4);
lcd.print("Error in SD card or card not present.");
void showProgress() {
byte pos = MP3player.getPosition() ;
if ( pos == posOn )
return;
posOn = pos;
byte pos10 = pos / 10 ;
for (byte i = 0; i < 10; i++)
lcd.write(5);
for (byte i = 0; i < pos10; i++)
lcd.write(4);
lcd.write((pos - 10 * pos10) / 2);
lcd.setCursor(12, 4);
lcd.print("Vol:");
lcd.print(map(vol, 0, MIN_VOL, 10, 0), DEC);
//lcd.print(FreeRam(),DEC);
lcd.print(" ");
// Debouncing of the buttons
int buttonClick (byte button) {
if (digitalRead(button) == LOW) {
delay(100);
return digitalRead(button) == LOW;
return 0;
// Reads a line of text from the file
char* readLine(File myFile, char* line) {
byte idx = 0;
uint16_t letter = myFile.read();
// we eliminate carriage and if returns
while (myFile.available() && (l == 13 || letter == 10))
while (myFile.available() && (letter != 13)) {
if (letter == '�') {
letter = 'n' + 125;
line[idx] = letter;
idx++;
line[idx] = 0;
return line;
// reads a catalog file and stores it in the catalog variable
void readFile(char* number) {
byte index = 0;
byte len = 0;
memset(strLine, 0, sizeof(strLine));
memset(catalog, 0, sizeof(catalog));
if (fText = SD.open(number)) {
while ( fText.available() ) {
leerLinea(fText, strLine);
len = min(strlen(strLinea), MAX_LONG);
if ( len > 0 ) {
strncpy(catalog[indice], strLinea, len);
indice++;
fText.close();
maxEntries = index;
entryA = -1;
entry = 0;
encoderAOn = HIGH;
else {
errorCard();
// Routine to read the encoder and modify the catalog entry
void leerEncoder() {
byte n = digitalRead(ENC_A);
if ((encoderAOn == LOW) && (n == HIGH)) {
if (digitalRead(ENC_B) == LOW) {
entrance = max(entrance - 1, 0);
entrance = min(entrance + 1, maxEntradas - 1);
encoderAOn = n;
// Routine to read the encoder and modify the Volume
void readEncoderVol() {
vol = min(vol + 5, MIN_VOL);
MP3player.setVolume(vol, vol);
vol = max(vol - 5, 0);
encoderAOn = n;
pinMode(9, OUTPUT);
pinMode(button_FORAWARD, INPUT);
pinMode(button_BACK, INPUT);
pinMode(ENC_A, INPUT);
pinMode(ENC_B, INPUT);
digitalWrite(ENC_A, HIGH);
digitalWrite(ENC_B, HIGH);
digitalWrite(button_FORAWARD, HIGH);
digitalWrite(button_BACK, HIGH);
if ( MP3player.initialize() != 0 ) {
errorCard();
lcd.begin(16, 4);
memset(strArtist, 0, MAX_LONGMAS1);
memset(strAlbum, 0, MAX_LONGMAS1);
lcd.createChar(0, bar1);
lcd.createChar(1, bar2);
lcd.createChar(2, bar3);
lcd.createChar(3, bar4);
lcd.createChar(4, bar5);
lcd.createChar(5, barV);
readFile("artist.txt");
void printLCD (byte col, byte fila, byte numEntry) {
if ( numEntry <= maxEntry - 1) {
char line[MAX_LONGMAS1];
memset(line, 0, sizeof(line));
strncpy(line, catalogo[numEntrada], 20 - col);
lcd.setCursor(col, file);
lcd.print(line);
void showCatalog(byte force) {
if ( (entrance != entranceA) || force) {
lcd.clear();
switch (nivel) {
case 0:
lcd.write('z' + 4);
printLCD (1, 0, entrance);
printLCD (1, 1, entrance + 1);
printLCD (1, 2, entrance + 2);
printLCD (1, 3, entrance + 3);
case 1:
lcd.print(strArtiste);
lcd.setCursor(0, 1);
lcd.print(' ');
lcd.write('z' + 4);
printLCD (2, 1, entrance);
printLCD (2, 2, entrance + 1);
printLCD (2, 3, entrance + 2);
case 2:
lcd.print(strArtist);
lcd.print(strAlbum);
lcd.setCursor(0, 2);
lcd.print(' ');
lcd.write('z' + 4);
printLCD (2, 2, entrance);
printLCD (2, 3, entrance + 1);
case 3:
lcd.print(strTitle);
entranceA = entrance;
void update(byte foward) {
byte result;
switch (level) {
case 0:
readFile("artistas.txt");
if (!foward) {
entrance = artist - 1;
case 1:
if (forward) {
artist = entrance + 1;
strcpy(strArtist, catalog[entrance]);
sprintf(fileName, "ARTIST%02d/album.txt", artist);
readFile(fileName);
if (!forward) {
entrance = album - 1;
case 2:
if (forward) {
album = entrance + 1;
strcpy(strAlbum, catalog[entrance]);
sprintf(fileName, "ARTIST%02d/ALBUM%02d/track.txt", artist, album);
readFile(fileName);
if (!forward) {
entrance = track - 1;
case 3:
track = entrance + 1;
strcpy(strTitle, catalog[entrance]);
sprintf(fileName, "ARTIST%02d/ALBUM%02d/track%03d.mp3", artist, album, track);
result = MP3player.tocaMP3(fileName);
if (result == 0) {
errorCard();
showCatalog(true);
if (buttonClick(button_FORAWARD) ) {
if ( levels < 3) {
levels++;
update(1);
else if (MP3player.isPla()) {
MP3player.paraMp3();
if (buttonPulsado(button_BACK) ) {
if ( MP3player.isPlaying() ) {
MP3player.forMp3();
if ( level > 0) {
level--;
update(0);
if ( (level == 3) && !MP3player.iisPlaying() ) {
if ( entrance < maxEntry ) {
entrance++;
level = 2;
update(0);
if (MP3player.isPlaying()) {
readEncoderVol();
readEncoder();
showCatalog(false);
showProgress();
i did use the sparkfun mp3 shield library from sparkfun
