Hi, I've recently started programming Arduino sketches.
I'm tring to make a controller of temperature, read current consumption of a pc and a monitor, moreover I need to read the rpm of two set of fans.
I only knew how to acquire temperature and use that information to control the fans, for read the current value I've copied an already written program that use a specific library to run; the program is called Energy Monitor and it's based on the Emonlib, at last for read the fan rpm I've copied a program that incorporates the attach interrupts.
Now when i run the program, on the serial monitor are printed all the values that i need but after the first cycle it doesn't print anything.
I'm asking for some help to understad why it stops, i post the code below, if you have some suggestion about how to acquire the current consumption without using a library based program I'll be grateful (I'm using a LEM HXS-20NP hall effect sensor).
I'm thinking that the Energy monitor program generates some problems in the regular flow of the program.
Here there is the link from which I copied the Energy monitor program:
https://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor
I've uploaded the library files of the Energy Monitor program that i used on dropbox:
Here it starts the code:
#include "EmonLib.h"
EnergyMonitor emon1;
EnergyMonitor emon2;
const byte errorPin=13;
int ris=6, ven=10, ven2=11, door=8,ledDoor=12;
word val;
float temperatura, temp;
int NbTopsFan,NbTopsFan1,calc,calc1, hallsensor=2,sta;
byte libero=5, libero1=9; //unused pins that i'll need afterwards
volatile byte state=LOW;
typedef struct{ //Defines the structure for multiple fans and their dividers
char fantype;
unsigned int fandiv;
}fanspec; //Definitions of the fans
fanspec fanspace[3]={{0,1},{1,2},{2,8}};
char fan=1;
void activate()
NbTopsFan++;
void activate1()
NbTopsFan1++;
pinMode(errorPin,OUTPUT);
pinMode(hallsensor,INPUT);
pinMode(3,INPUT);
pinMode(door,INPUT);
pinMode(ledDoor,OUTPUT);
pinMode(ris,OUTPUT);
pinMode(ven,OUTPUT);
attachInterrupt(0,activate,RISING);
attachInterrupt(1,activate1,RISING);
emon1.voltage(A2,234.26,1.7);
emon1.current(A1,111.1);
emon2.voltage(A4,234.26,1.7);
emon2.current(A3,111.1);
Serial.flush();
emon1.calcVI(20,2000);
Serial.println("PC_Sensor:");
emon1.serialprint();
emon1.statusPC();
emon2.calcVI(20,2000);
Serial.println("Monitor_Sensor:");
emon2.serialprint();
emon2.statusMonitor();
val=analogRead(A0);
temperatura=(float)val/1023*5;
temp=(float)temperatura/0.01-50;
Serial.print("temperatura: ");
Serial.print(temp);
Serial.println("^C");
NbTopsFan = 0;
sei(); //Enables interrupts
delay (1000);
cli(); //Disable interrupts
calc = ((NbTopsFan * 60)/fanspace[fan].fandiv);
//Times NbTopsFan (which is apprioxiamately the fequency the fan is spinning at) by 60 seconds //before dividing by the fan's divider
Serial.print (" set ventole 1: ");
Serial.print (calc, DEC);
Serial.print (" rpm\r\n");
NbTopsFan1 = 0;
delay (1000);
calc1 = ((NbTopsFan1 * 60)/fanspace[fan].fandiv);
Serial.print (" set ventole 2: ");
Serial.print (calc1, DEC);
sta=digitalRead(door);
digitalWrite(ledDoor,sta);
digitalWrite(errorPin,state);
if(val<143){
digitalWrite(ris,HIGH); //controllo temperatura interna
digitalWrite(ven,LOW);
digitalWrite(ven2,LOW);} //superata la soglia avvia le ventole
if(143<=val<=174){
digitalWrite(ris,LOW);
if(val>174){
digitalWrite(ven,HIGH);
digitalWrite(ven2,HIGH);}
if(digitalRead(ven)==HIGH && NbTopsFan==0){ //controlla se supera la temperatura
digitalWrite(errorPin,HIGH); //e se le ventole entrano in funzione
Serial.println("errore: il set di ventole 1 non sta girando");} //in caso non funzionasse segnala l'errore
if(digitalRead(ven)==HIGH&&NbTopsFan!=0){
digitalWrite(errorPin,LOW);}
if(digitalRead(ven)==HIGH && NbTopsFan1==0){
Serial.println("errore: il set di ventole 2 non sta girando");}
if(digitalRead(ven)==HIGH&&NbTopsFan1!=0){
Thank you for any suggestion.
