ARDUINO NANO 33 BLE - ArduinoBLE library
Hello,
We are going to use ArduinoBLE library for a project on nano 33 IoT. Should we expect that the NINA module is preflushed with Arduino NINA-W102 firmware, as the library demands?
Many thanks,
Alex
The NINA module does indeed come pre-flashed with the firmware. There is also an easy system for updating the NINA firmware when new versions become available:
I don't see how this is easy to use with the nano not 33 its not compatible!!
russell_roberts:
I don’t see how this is easy to use with the nano not 33 its not compatible!!
what is “nano not 33”?
its called spell check.
what do think it means?
Is it this nano? This might be considered "not 33" because it uses the older 5V logic levels instead of the newer 3.3V logic levels. The CPU is also very different.
https://store.arduino.cc/usa/arduino-nano
russell_roberts:
Nano? this is "not 33"
Nano Every? this is too "not 33"
Nano 33 Iot? this is 33, but "Iot" is similar to "not"
Nano 33 BLE? this is 33
