Hello ! I am trying to measure the capacitance value using Arduino Nano 33 ble. I know the Arduino Nano 33 ble is based on the Uno and other chips. When only the pullup resistance and stray capacitance values are changed, the measurement is not good. If I need to completely change the coding, does anyone know how to measure capacitance using Arduino Nano 33 ble?
Here is my code (Used on Unoboard)
#include <ArduinoBLE.h>
const int OUT_PIN = A2;
const int IN_PIN = A1;
const float IN_STRAY_CAP_TO_GND = 24.48;
const float IN_CAP_TO_GND = IN_STRAY_CAP_TO_GND;
const float R_PULLUP = 34.8;
const int MAX_ADC_VALUE = 1023;
pinMode(OUT_PIN, OUTPUT);
pinMode(IN_PIN, OUTPUT);
pinMode(IN_PIN, INPUT);
digitalWrite(OUT_PIN, HIGH);
int val = analogRead(IN_PIN);
digitalWrite(OUT_PIN, LOW);
if (val < 1000)
float capacitance = (float)val * IN_CAP_TO_GND / (float)(MAX_ADC_VALUE - val);
Serial.print(F("C:"));
Serial.print(capacitance, 3);
Serial.print(F(" pF ("));
Serial.print(val);
Serial.println(F(") "));
delay(1);
pinMode(OUT_PIN, INPUT_PULLUP);
unsigned long u1 = micros();
unsigned long t;
int digVal;
do
digVal = digitalRead(OUT_PIN);
unsigned long u2 = micros();
t = u2 > u1 ? u2 - u1 : u1 - u2;
} while ((digVal < 1) && (t < 400000L));
pinMode(OUT_PIN, INPUT);
val = analogRead(OUT_PIN);
digitalWrite(IN_PIN, HIGH);
int dischargeTime = (int)(t / 1000L) * 5;
delay(dischargeTime);
digitalWrite(IN_PIN, LOW);
float capacitance = -(float)t / R_PULLUP
/ log(1.0 - (float)val / (float)MAX_ADC_VALUE);
if (capacitance > 1000.0)
Serial.print(capacitance / 1000.0, 2);
Serial.print(F(" uF"));
Serial.print(capacitance, 2);
Serial.print(F(" nF"));
