Arduino nano 33 BLE, how to turn on builtin bluetooth code?
I am new to programming and I am doing a project on an Arduino nano 33 BLE. So far I have found the sample code on the simple accelerometer on the IDE, I am wondering how to proceed with turning on the bluetooth functionality. I do not have the physical device with me because of the pandemic. So far I have included the #include <ArduinoBLE.h>
What I am trying to do is I need the Arduino to turn on once (void setup) and then proceed to other commands in the void loop section. Also I am aware that it would print something, what I intend is for the Arduino to simply communicate with an Android device with readings from other components in the void loop section.
So far I have:
BLEService moduleService
while (!Serial);
Serial.println("started")l
if ( !BLE.begin()) {
Serial.println("Failed to initialize BLE!");
while (1);
Should I continue basing off this code on the simple accelerometer example?
perhaps you should try reading a tutorial first Get Started with Arduino Nano 33 BLE - OKdo
ieee488:
when searching for how to do this I never saw that tutorial. Thank you very much for your help!
