I am very new to the Arduino community and I could really use some help. I am creating a project that will use the input from the x-axis accelerometer to control the output of LEDs. I have no problem reading the output from the x-axis, but I find that when I move my project in the y-axis, it affects the x-axis readings. My project needs to read the deceleration of the x-axis without any other interference. How do I isolate the x-axis reading?
Yes it will that is how these things work. This is because you can't move just one axis without moving the others as well. It is a physical impossibility.
Maybe I don't understand how the BMI270 works. I would think that each axis should be independent. Let's say the x-axis is forward & aft while the y-axis is left & right. How is moving left and right going to affect the forward & aft acceleration? Or is this just how the BMI270 is designed? I need to find a way to read the x-axis without interference from the y-axis. Can this be done?
I understand that when i move out left/right that i will push it fwd/aft a bit, but the readings I get seem excessive. My project measures the deceleration of a vehicle. The faster the vehicle decelerates, the more LEDs light up, so i need real time x- axis data. Maybe the Nano 33 BLE Sense is not the ideal board for this project.
If you have any suggestions to help, they would be greatly speciation.
