Arduino Nano 33 BLE Sense Using With ESP8266 For Telegram Bots
Hi all, good afternoon. I have a problem with my project. I'm using arduino nano 33 ble sense, but i'm also using esp8266 model 01 to connect to telegram bots to display notifications from the system. but when I compile my coding, if the board I choose is arduno nano 33 ble sense on arduino IDE, the coding is an error. such as: Error compiling for Arduino Nano 33 BLE board. can someone give me a solution please!
Arduino: 1.8.15 (Windows 10), Board: "Arduino Nano 33 BLE"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Cindi Alfani\Documents\Arduino\libraries -fqbn=arduino:mbed:nano33ble -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\CINDIA~1\AppData\Local\Temp\arduino_build_704466 -warnings=none -build-cache C:\Users\CINDIA~1\AppData\Local\Temp\arduino_cache_58689 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.openocd.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.rp2040tools.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -verbose C:\Users\Cindi Alfani\Documents\SKRIPSI\PROJECT AI\SKRIPSI CINDI\BERKAS SEMHAS\BERKAS SEMHAS\Source Code\AKURASI 93%\TA FIX CINDI BISMILLAH\CT_Bot\CT_Bot.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Cindi Alfani\Documents\Arduino\libraries -fqbn=arduino:mbed:nano33ble -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\CINDIA~1\AppData\Local\Temp\arduino_build_704466 -warnings=none -build-cache C:\Users\CINDIA~1\AppData\Local\Temp\arduino_cache_58689 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.openocd.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.rp2040tools.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -verbose C:\Users\Cindi Alfani\Documents\SKRIPSI\PROJECT AI\SKRIPSI CINDI\BERKAS SEMHAS\BERKAS SEMHAS\Source Code\AKURASI 93%\TA FIX CINDI BISMILLAH\CT_Bot\CT_Bot.ino
Using board 'nano33ble' from platform in folder: C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\hardware\mbed\2.1.0
Using core 'arduino' from platform in folder: C:\Users\Cindi Alfani\AppData\Local\Arduino15\packages\arduino\hardware\mbed\2.1.0
Detecting libraries used...
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\CINDIA~1\\AppData\\Local\\Temp\\arduino_build_704466\\sketch\\CT_Bot.ino.cpp" -o nul
Alternatives for CTBot.h: [CTBot-2.1.7@2.1.7]
ResolveLibrary(CTBot.h)
  -> candidates: [CTBot-2.1.7@2.1.7]
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\CINDIA~1\\AppData\\Local\\Temp\\arduino_build_704466\\sketch\\CT_Bot.ino.cpp" -o nul
Alternatives for ArduinoJson.h: [ArduinoJson-6.x@6.18.3]
ResolveLibrary(ArduinoJson.h)
  -> candidates: [ArduinoJson-6.x@6.18.3]
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\ArduinoJson-6.x\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\CINDIA~1\\AppData\\Local\\Temp\\arduino_build_704466\\sketch\\CT_Bot.ino.cpp" -o nul
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\ArduinoJson-6.x\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src\\CTBot.cpp" -o nul
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\ArduinoJson-6.x\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src\\CTBotInlineKeyboard.cpp" -o nul
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\ArduinoJson-6.x\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src\\CTBotReplyKeyboard.cpp" -o nul
"C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src" "-IC:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\ArduinoJson-6.x\\src" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\cores\\arduino" "@C:\\Users\\Cindi Alfani\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\2.1.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\Cindi Alfani\\Documents\\Arduino\\libraries\\CTBot-2.1.7\\src\\CTBotSecureConnection.cpp" -o nul
Alternatives for WiFiClientSecure.h: []C:\Users\Cindi Alfani\Documents\Arduino\libraries\CTBot-2.1.7\src\CTBotSecureConnection.cpp:1:10: fatal error: WiFiClientSecure.h: No such file or directory
ResolveLibrary(WiFiClientSecure.h) #include <WiFiClientSecure.h>
  -> candidates: []          ^~~~~~~~~~~~~~~~~~~~
compilation terminated.
Using library CTBot-2.1.7 at version 2.1.7 in folder: C:\Users\Cindi Alfani\Documents\Arduino\libraries\CTBot-2.1.7
Using library ArduinoJson-6.x at version 6.18.3 in folder: C:\Users\Cindi Alfani\Documents\Arduino\libraries\ArduinoJson-6.x
exit status 1
Error compiling for board Arduino Nano 33 BLE.
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
okey thanks, i'm so sorry if my question is not in accordance with step to use the forum.
