Arduino Nano 33 BleSense, problems of disconnection ble from iOS device
HI,
Iam using the Arduino Nano 33 BleSense board as peripheral and an Ipad pro / iPhone X as central to receive the data. I have the following issues:
  1. If I am setting the localName --BLE.setLocalName for the Advertising name and I am trying to connect to the iPad /iPhone it shows the default Advertising name “Arduino” and not the one set via BLE.setDevice.
    I figured out, that using the setDeviceName it works in iOS, so it means that as soon as it is paired, the device name is used as an advertising name.
    If I am trying to pair the Arduino to an Android phone, then it works like in the examples given in the Arduino page with using the setLocalName. Is there a compatibility problem with iOS?
  2. My second issue is the following:
    If I want to disconnect, it looks like that the Arduino Board is still connected with Bluetooth. It still keeps the ble connection on. This issue is again only a problem with the iOS. If I am using an Android phone everything works fine. Do you know how to solve this problem?
    This is the example sketch that I used: it is the BatteryMonitor that I adapted for my own purpose:
  Battery Monitor
  This example creates a BLE peripheral with the standard battery service and
  level characteristic. The A0 pin is used to calculate the battery level.
  The circuit:
  - Arduino MKR WiFi 1010, Arduino Uno WiFi Rev2 board, Arduino Nano 33 IoT,
    Arduino Nano 33 BLE, or Arduino Nano 33 BLE Sense board.
  You can use a generic BLE central app, like LightBlue (iOS and Android) or
  nRF Connect (Android), to interact with the services and characteristics
  created in this sketch.
  This example code is in the public domain.
#include <ArduinoBLE.h>
 // BLE Battery Service
BLEService batteryService("180F");
// BLE Battery Level Characteristic
BLEUnsignedCharCharacteristic batteryLevelChar("2A19",  // standard 16-bit characteristic UUID
    BLERead | BLENotify); // remote clients will be able to get notifications if this characteristic changes
int oldBatteryLevel = 0;  // last battery level reading from analog input
long previousMillis = 0;  // last time the battery level was checked, in ms
  Serial.begin(9600);    // initialize serial communication
  while (!Serial);
  pinMode(LED_BUILTIN, OUTPUT); // initialize the built-in LED pin to indicate when a central is connected
  // begin initialization
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while (1);
  /* Set a local name for the BLE device
     This name will appear in advertising packets
     and can be used by remote devices to identify this BLE device
     The name can be changed but maybe be truncated based on space left in advertisement packet
  BLE.setLocalName("BatteryMonitor");
  BLE.setAdvertisedService(batteryService); // add the service UUID
  batteryService.addCharacteristic(batteryLevelChar); // add the battery level characteristic
  BLE.addService(batteryService); // Add the battery service
  batteryLevelChar.writeValue(oldBatteryLevel); // set initial value for this characteristic
  /* Start advertising BLE.  It will start continuously transmitting BLE
     advertising packets and will be visible to remote BLE central devices
     until it receives a new connection */
  // start advertising
  BLE.advertise();
  Serial.println("Bluetooth device active, waiting for connections...");
  // wait for a BLE central
  BLEDevice central = BLE.central();
  // if a central is connected to the peripheral:
  if (central) {
    Serial.print("Connected to central: ");
    // print the central's BT address:
    Serial.println(central.address());
    // turn on the LED to indicate the connection:
    digitalWrite(LED_BUILTIN, HIGH);
    // check the battery level every 200ms
    // while the central is connected:
    while (central.connected()) {
      long currentMillis = millis();
      // if 200ms have passed, check the battery level:
      if (currentMillis - previousMillis >= 200) {
        updateBatteryLevel();
    // when the central disconnects, turn off the LED:
    digitalWrite(LED_BUILTIN, LOW);
    Serial.print("Disconnected from central: ");
void updateBatteryLevel() {
  /* Read the current voltage level on the A0 analog input pin.
     This is used here to simulate the charge level of a battery.
  int battery = analogRead(A0);
  int batteryLevel = map(battery, 0, 1023, 0, 100);
  if (batteryLevel != oldBatteryLevel) {      // if the battery level has changed
    Serial.print("Battery Level % is now: "); // print it
    Serial.println(batteryLevel);
    batteryLevelChar.writeValue(batteryLevel);  // and update the battery level characteristic
    oldBatteryLevel = batteryLevel;           // save the level for next comparison
