Hello, I've been trying to connect my nano 33 iot to aws iot to make a request to a topic, however i can't seem to find a way to attach the certificates hence i'm getting this error
#include <WiFiNINA.h>
#include <MQTT.h>
// SSL client and MQTT client setup
WiFiSSLClient net;
MQTTClient client(256);
// Wi-Fi credentials
const char* ssid = "WIFI_NETWORK";
const char* password = "";
// AWS IoT endpoint (replace with your actual endpoint)
const char* aws_endpoint = "xxxx-ats.iot.us-east-1.amazonaws.com";
// MQTT topic to publish to
const char* topic = "topic/test";
// Amazon Root CA Certificate (replace with your actual certificate)
const char ca_cert[] PROGMEM = R"EOF(
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
)EOF";
// Device Certificate (replace with your actual certificate)
const char device_cert[] PROGMEM = R"EOF(
)EOF";
// Private Key (replace with your actual private key)
const char private_key[] PROGMEM = R"EOF(
-----BEGIN RSA PRIVATE KEY-----
-----END RSA PRIVATE KEY-----
)EOF";
// Initialize serial communication for debugging
delay(100);
// Check if the WiFi module is present
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("WiFi module not detected");
while (true);
// Connect to Wi-Fi
Serial.print("Connecting to Wi-Fi...");
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("\nConnected to Wi-Fi");
// Initialize MQTT client with AWS IoT endpoint and secure connection
client.begin(aws_endpoint, 8883, net);
Serial.println("MQTT client setup complete.");
// MQTT connection and communication code
if (!client.connected()) {
Serial.println("Attempting MQTT connection...");
if (client.connect("ArduinoNano33IoT")) { // Use unique client ID
Serial.println("Connected to AWS IoT");
// Publish data to the topic
String message = "{\"temperature\": 25.0, \"humidity\": 60.0}"; // Example data payload
client.publish(topic, message);
Serial.println("Data published to topic: " + String(topic));
Serial.print("Failed to connect, status: ");
Serial.println(client.lastError());
delay(5000); // Retry after a short delay
client.loop();
delay(10000); // Wait 10 seconds before sending the next message
Connected to Wi-Fi
Failed to connect, status: -3
