Not with AVR specific code though. That PORTD line will just be an error on a SAM or ESP platform. Again, the AVR code you have is a red herring. It's adding confusion to what should be simple.
Thank you for the heads up! I am used to set and read pins using registers but forgot they are hardware specific. I'll just use digitalWrite. Or maybe since the SAMD chip is made by Microchip it uses some similar registers as the PIC family which I already know how to use. I should try.
Why guess? Just look at the datasheet and save yourself the time.
program using two SAMD21 timers to generate square wave 5KHz on pin 6 and 10KHz on pin 7
// MKRFOX 1200 (SAMS21) timer test - generate square wave 5KHz on pin 6 and 10KHz on pin 7
// NOTE: square waves are not syncronised
// from g https://github.com/khoih-prog/SAMD_TimerInterrupt
#if !(defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
|| defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
|| defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) \
|| defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) || defined(__SAMD51__) || defined(__SAMD51J20A__) \
|| defined(__SAMD51J19A__) || defined(__SAMD51G19A__) || defined(__SAMD51P19A__) \
|| defined(__SAMD21E15A__) || defined(__SAMD21E16A__) || defined(__SAMD21E17A__) || defined(__SAMD21E18A__) \
|| defined(__SAMD21G15A__) || defined(__SAMD21G16A__) || defined(__SAMD21G17A__) || defined(__SAMD21G18A__) \
|| defined(__SAMD21J15A__) || defined(__SAMD21J16A__) || defined(__SAMD21J17A__) || defined(__SAMD21J18A__))
#error This code is designed to run on SAMD21/SAMD51 platform! Please check your Tools->Board setting.
#endif
// These define's must be placed at the beginning before #include "SAMDTimerInterrupt.h"
// _TIMERINTERRUPT_LOGLEVEL_ from 0 to 4
// Don't define _TIMERINTERRUPT_LOGLEVEL_ > 0. Only for special ISR debugging only. Can hang the system.
// Don't define TIMER_INTERRUPT_DEBUG > 2. Only for special ISR debugging only. Can hang the system.
#define TIMER_INTERRUPT_DEBUG 0
#define _TIMERINTERRUPT_LOGLEVEL_ 0
// Select only one to be true for SAMD21. Must must be placed at the beginning before #include "SAMDTimerInterrupt.h"
#define USING_TIMER_TC3 true // Only TC3 can be used for SAMD51
#define USING_TIMER_TC4 true // Not to use with Servo library
#define SQUARE_WAVE_PIN3 6 // pin to output square wave
#define SQUARE_WAVE_PIN4 7 // pin to output square wave
#define TIMER_INTERVAL_US 50 // timer interval in uSec
// Depending on the board, you can select SAMD21 Hardware Timer from TC3, TC4, TC5, TCC, TCC1 or TCC2
// SAMD51 Hardware Timer only TC3
SAMDTimer ITimer3(TIMER_TC3);
SAMDTimer ITimer4(TIMER_TC4);
// timer interrupt routine
volatile int counter3;
void TimerHandler_TIMER_TC3() {
counter3++;
//timer interrupt toggles pin SQUARE_WAVE_PIN
digitalWrite(SQUARE_WAVE_PIN3, !digitalRead(SQUARE_WAVE_PIN3));
volatile int counter4;
void TimerHandler_TIMER_TC4() {
counter4++;
digitalWrite(SQUARE_WAVE_PIN4, !digitalRead(SQUARE_WAVE_PIN4));
pinMode(SQUARE_WAVE_PIN3, OUTPUT);
pinMode(SQUARE_WAVE_PIN4, OUTPUT);
while (!Serial && millis() < 5000)
delay(100);
Serial.print(F("\nStarting TimerInterruptTest on "));
Serial.println(BOARD_NAME);
Serial.println(SAMD_TIMER_INTERRUPT_VERSION);
Serial.print(F("CPU Frequency = "));
Serial.print(F_CPU / 1000000);
Serial.println(F(" MHz"));
// Interval in microseconds
if (ITimer3.attachInterruptInterval(TIMER_INTERVAL_US * 5, TimerHandler_TIMER_TC3)) {
} else
Serial.println(F("Can't set ITimer3. Select another freq. or timer"));
if (ITimer4.attachInterruptInterval(TIMER_INTERVAL_US, TimerHandler_TIMER_TC4)) {
} else
Serial.println(F("Can't set ITimer4. Select another freq. or timer"));
// ecery second print interupt counter
static long timer = millis();
if (millis() - timer > 1000) {
timer = millis();
Serial.print("counter3 ");
Serial.print(counter3);
Serial.print(" counter4 ");
Serial.println(counter4);
counter3 = counter4 = 0;
serial monitor output
Starting TimerInterruptTest on __SAMD21G18A__
SAMDTimerInterrupt v1.10.1
CPU Frequency = 48 MHz
counter3 4003 counter4 20018
counter3 4003 counter4 20021
counter3 4003 counter4 20016
counter3 4003 counter4 20017
counter3 4003 counter4 20019
oscilloscope output
NOTE: square waves are not syncronised only appear so on scope because I have stopped the run
to synchronise generate the 2KHz from the 10KHz interrupt, e.g. every fifth interrupt invert the 2KHz output
Nice. How could I temporary stop the interrupt from being executed like this?
noInterrupts(); // Stop ISR
// Do something
interrupts(); // Restart executing the ISR
SAMDTimerInterrupt has the following methods
void detachInterrupt();
void disableTimer();
void reattachInterrupt();
void enableTimer();
probably disableTimer() and enableTimer() would do what you require
EDIT: example with 10KHz and 2KHz square waves - timer disabled/enabled on a keyboard hit
// MKRFOX 1200 (SAMS21) timer test - generate square wave 2KHz on pin 6 and 10KHz on pin 7
// - timer disabled/enabled on a keyboard hit
#endif
volatile int counter3, counter4;
static int counter_2KHz = 5;
counter3++;
if (--counter_2KHz == 0) {
counter_2KHz = 5;
counter4++;
delay(100);
if (ITimer3.attachInterruptInterval(TIMER_INTERVAL_US, TimerHandler_TIMER_TC3)) {
} else
timer = millis();
// keyboard hit disable/enable timer
if (Serial.available()) {
static bool enabled = true;
Serial.read();
if (enabled) {
ITimer3.disableTimer();
Serial.println("keyboard hit disabled timer");
ITimer3.enableTimer();
Serial.println("keyboard hit enabled timer");
enabled = !enabled;
serial monitor output - counter goto 0 when timer is disabled
counter3 20015 counter4 4003
counter3 20016 counter4 4003
counter3 20017 counter4 4004
counter3 0 counter4 0
counter3 20014 counter4 4003
counter3 1 counter4 0
Edit: maybe worth updating the post title to reflect that it is a SAMD21 that is using timer interrupts
