Arduino nano 33 Iot in Blink
For a course of Iot I used an ESP 32 and conected it to the app blink, however, for a project I am using the Arduino nano 33 IoT, did someone know if the app work also with this board? I am saying that because when I select the board It only put me the Arduino nano.
Thanks for your help!
Does it have an option to select Arduino MKR WiFi 1010? If so, try that one. The Nano 33 IoT is functionally the same, only in the Nano form factor rather than the MKR form factor.
Blynk?
this is for any WiFi library (or Ethernet library with a little more straightforward changes)
#include <WiFiNINA.h>
#include <Adapters/BlynkWiFiCommon.h>
WiFiClient _blynkWifiClient;
BlynkArduinoClient _blynkTransport(_blynkWifiClient);
BlynkWifiCommon Blynk(_blynkTransport);
in setup()
 int status = WL_DISCONNECTED;
 while ( status != WL_CONNECTED) {
   status = WiFi.begin(ssid, pass);
 Blynk.config(auth, BLYNK_DEFAULT_DOMAIN, BLYNK_DEFAULT_PORT);
 while (!Blynk.connect());
pert:
hi,
yes this board is in the list of supported boards
thanks !
