Arduino nano 33 iot no sleep mode
I make an application that records temperatures every x minutes, the problem I see is that the arduino goes to sleep. Is there a way to disable this function?
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
I found these libraries to add but I always get an error when installing the zips I find.
With this watch my project is falling apart, if anyone has a solution.
Maybe using one pin out and one pin in and sending a signal every x minutes could prevent the watch?
Thank you in advance for your help
The Arduino never sleeps without being told so.
These aren't libraries but part of the platform core (think of it being part of the IDE). So you don't have to install any ZIP.
As we have no clue what project you're talking about and why it should fall apart we cannot help here.
If the arduino stops it means that it has an error and it crashes.
I'm going to look into this.
I put the code here. I do have ideas like writing to a file, my generated web page that may be causing my problem.
Thanks for your help
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <TimeLib.h>
#include "max6675.h"
#include <SPI.h>
#include <SD.h>
//#include <avr/interrupt.h>
//#include <avr/power.h>
//#include <avr/sleep.h>
//#include <avr/wdt.h>
 *                                             I N I T I A L I S E
    //                         Variables configurables
      char bufferSsid[25]= "xxx";                       //"Le_Paradis";
      char bufferPass[25] = "xxx";                      //"lerobuste";
      char bufferServeurTemps[25] = "xxxx.pool.ntp.org";//"europe.pool.ntp.org";
      char bufferIPServeur[25] = "xxx.xxx.xxx.xxx";     //"192.168.1.53";
      int RefresHTML = 10;
      String valeurs[6][2]={{"Int.","0"},{"Ext.","0"},{"libr","0"},{"libr","0"},{"libr","0"},{"libr","0"}};
      int tempo = 1; // interval de temps en MINUTES entre chaque sauvegarde
char *ssid = bufferSsid;
char *pass = bufferPass;
char *ServeurTemps = bufferServeurTemps;
char *IPServeur = bufferIPServeur;
int status = WL_IDLE_STATUS;
unsigned int localPort = 1968;
char packetBuffer[255];
boolean clientconnecte=false;
String wifiIP;
unsigned int debut = 0;
byte h_, j_, m_;
byte page = 0;
byte nbPassages = 0;
byte thermo1S0 = 2; // so    (vert)
byte thermo1CLK = 3; // sck  (jaune)
byte thermo1CS = 4; // unique pour le thermocouple 1
byte thermo2CS = 5; // unique pour le thermocouple 2
byte thermo3CS = 6; // unique pour le thermocouple 3
byte thermo4CS = 7; // unique pour le thermocouple 4
byte thermo5CS = 8; // unique pour le thermocouple 5
byte thermo6CS = 9; // unique pour le thermocouple 6
WiFiUDP udp;
WiFiServer server(80);
WiFiClient client;
NTPClient timeClient(udp, ServeurTemps, 3600, 60000);
MAX6675 thermocouple1(thermo1CLK, thermo1CS, thermo1S0);
MAX6675 thermocouple2(thermo1CLK, thermo2CS, thermo1S0);
MAX6675 thermocouple3(thermo1CLK, thermo3CS, thermo1S0);
MAX6675 thermocouple4(thermo1CLK, thermo4CS, thermo1S0);
MAX6675 thermocouple5(thermo1CLK, thermo5CS, thermo1S0);
MAX6675 thermocouple6(thermo1CLK, thermo6CS, thermo1S0);
byte sdCS = 10;
Sd2Card CarteSD;
SdVolume VolumeCarteSD;
uint32_t volumesize;
 *                                                   S E T U P
  udp.begin(localPort);
  Serial.println("Initialisation carte SD");
  if (!CarteSD.init(SPI_HALF_SPEED, sdCS)) {
    Serial.println(F("Échec lors de l'initialisation. Essayez de jeter un coup d'oeil à : "));
    Serial.println(F("- est-ce que la carte SD est bien insérée dans le lecteur ?"));
    Serial.println(F("- est-ce que vos branchements électriques sont corrects ?"));
    Serial.println(F("- est-ce que le 'chipSelect' choisi dans le programme correspond bien à celui branché sur l'arduino ? (pin D10, par défaut)"));
    Serial.println(F("Appuyez sur RESET pour relancer le programme, au besoin."));
    Serial.println(F("Câblage correct, carte SD trouvée."));
  // Étape 2 : déterminer le type de carte SD insérée dans le lecteur
  Serial.print(F("Type de carte SD insérée : "));
  switch (CarteSD.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println(F("SD1"));
    case SD_CARD_TYPE_SD2:
      Serial.println(F("SD2"));
    case SD_CARD_TYPE_SDHC:
      Serial.println(F("SDHC"));
    default:
      Serial.println(F("Inconnu"));
  if (!VolumeCarteSD.init(CarteSD)) {
    Serial.println(F("Aucune partition FAT16/FAT32 trouvée."));
    Serial.println(F("Vérifiez si votre carte SD est bien formatée !"));
  //  while (1);      // Boucle infinie, arrêt du programme
    Serial.print(F("Format du volume : FAT"));
    Serial.println(VolumeCarteSD.fatType(), DEC);
   if (!SD.begin(sdCS)) {
     Serial.println("L'initialisation de la carte SD a échouée !");
    // return;
    Serial.println("----------------");
    Serial.println("Lecture carte SD");
    lireConf();
    if (SD.exists("config.ini") == false ) {
        envoyerConf();
        //             le fichier de config est à compléter, allumer led pour indiquer
    Serial.print("------------------------>");Serial.println(ssid);
    Serial.print("------------------------>");Serial.println(pass);
    Serial.print("------------------------>");Serial.println(ServeurTemps);
    Serial.print("------------------------>");Serial.println(IPServeur);
    Serial.print("------------------------>");Serial.println(tempo);
    Serial.print("------------------------>");Serial.println(valeurs[0][0]);
    Serial.print("------------------------>");Serial.println(valeurs[1][0]);
    Serial.print("------------------------>");Serial.println(valeurs[2][0]);
  Serial.print("Réseau Wifi : ");
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication WiFi Echec!");
    // don't continue
   // while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    //Serial.println("Please upgrade the firmware");
  while (status != WL_CONNECTED) {
    Serial.println("Mince, WIFI non connecté");
    status = WiFi.begin(ssid, pass);
  Serial.println("WIFI connecté, ouf !");
  wifiIP = String(WiFi.localIP());
  server.begin();
  client = server.available();
  timeClient.begin();
  timeClient.update();
  Serial.println("========== Initialisation terminé ==========");
  debut = timeClient.getEpochTime();
 *                                                    L O O P
   String request = "";
   if (client) {
        request = client.readStringUntil('\r\n');
        if (request.indexOf("/NOMS=") != -1) {
          request = request.substring(request.indexOf("=")+1);
          request = request.substring(0, request.indexOf("m"));
          for (byte i=0; i<6 ; i++) {
            String txt = request.substring(request.indexOf("["+String(i)+"]"));
            valeurs[i][0] = txt.substring(3,txt.indexOf(";"));
          envoyerConf();
        if (request.indexOf("/TEMP=") != -1) {
          j_=request.substring(0, request.indexOf("j")).toInt();
          h_=request.substring(request.indexOf("j")+1, request.indexOf("h")).toInt();
          m_=request.substring(request.indexOf("h")+1, 255).toInt();
          tempo = (j_*24+h_)*60+m_;
          //Serial.print(j_);Serial.print(" ");Serial.print(h_);Serial.print(":");Serial.print(m_);Serial.print("==>");Serial.println(tempo);
          envoyerConf();
        if (request.indexOf("/SERVERTEMPS=") != -1) {
          request = request.substring(0, request.indexOf(";"));
          request.toCharArray(bufferServeurTemps, request.length() + 1);
          envoyerConf();
        if (request.indexOf("/SERVER=") != -1) {
          request.toCharArray(bufferIPServeur, request.length() + 1);
          envoyerConf();
        if (request.indexOf("/SSID=") != -1) {
          request.toCharArray(bufferSsid, request.length() + 1);
          ssid = bufferSsid;
          envoyerConf();
        if (request.indexOf("/PASS=") != -1) {
          request.toCharArray(bufferPass, request.length() + 1);
          pass = bufferPass;
          envoyerConf();
        if (request.indexOf("/EFFACE=") != -1) {
          SD.remove("mesures.txt");
        if (request.indexOf("/RETOUR=") != -1) {
          page = 0;
        if (request.indexOf("/DATA=") != -1) {
          page = 1;
        if (request.indexOf("/CONFIG=") != -1) {
          page = 2;
        if (request.indexOf("/VARIABLES=") != -1) {
          page = 3;
        if (request.indexOf("/GRAPH=") != -1) {
          page = 4;
        if (!clientconnecte) {
            while (!client.available()) { delay(10); }
        clientconnecte=true;
        String request = client.readStringUntil('\r\n');
        client.flush();
        h_ = tempo/60;
        m_ = tempo - h_ * 60;
        j_ = h_ / 24;
        h_ = h_ - j_* 24;
        switch (page) {
          case 0 : html(); break;
          case 1 : html2(); break;
          case 2 : html3(); break;
          case 3 : html4(); break;
          case 4 : html5(); break;
        client.stop();
    } else { clientconnecte=false; }
  if (nbPassages >= 2000/50) {
      sleep_disable();
      valeurs[0][1]=String(thermocouple1.readCelsius(),1);
      valeurs[1][1]=String(thermocouple2.readCelsius(),1);
      valeurs[2][1]=String(thermocouple3.readCelsius(),1);
      valeurs[3][1]=String(thermocouple4.readCelsius(),1);
      valeurs[4][1]=String(thermocouple5.readCelsius(),1);
      valeurs[5][1]=String(thermocouple6.readCelsius(),1);
      Serial.print(valeurs[0][1]);Serial.print("--");Serial.print(valeurs[1][1]);Serial.print("--");Serial.println(valeurs[2][1]);
      unsigned long unix_epoch = timeClient.getEpochTime();
      if (unix_epoch - debut >= tempo*60) {
          for (byte ii=0; ii<6; ii++) {
              if (valeurs[ii][0]!="libr") {
                  int v = valeurs[ii][1].toFloat()*10;
                  ecrire(ii, v , valeurs[ii][0]);
          debut = unix_epoch;
      for (int ii=0; ii<6; ii++) {
            int v = valeurs[ii][1].toFloat()*100;
            envoyer(String(ii)[0], v, valeurs[ii][0]);
      nbPassages=0;
  nbPassages=nbPassages+1;
  delay(50);
 *                                                    S U B
String zero(int nb) {
    static char buf[2];
    sprintf(buf,"%02d",nb);
    return String(buf);
void envoyer(char donnee, int valeur, String txt) {
  String txt_ = txt;
  if (valeur>200000) {return;}
  int packetSize = udp.parsePacket();
  char buf[25];
  udp.beginPacket(IPServeur, localPort);
  sprintf(buf, "%c:%i;%c%c%c%c", donnee, valeur, txt[0], txt[1], txt[2], txt[3]);
  udp.write(buf);
  udp.write("\r\n");
  udp.endPacket();
void ecrire(byte nb, int valeur, String txt) {
    File myFile;
    myFile = SD.open("mesures.txt", FILE_WRITE);
    myFile.print("[");
    myFile.print(nb);
    myFile.print("]");
    myFile.print(zero(day(unix_epoch)));
    myFile.print("/");
    myFile.print(zero(month(unix_epoch)));
    myFile.print("/");
    myFile.print(year(unix_epoch));
    myFile.print(" ");
    myFile.print(zero(hour(unix_epoch)+1));
    myFile.print(":");
    myFile.print(zero(minute(unix_epoch)));
    myFile.print(" (");
    myFile.print(unix_epoch);
    myFile.print(") ");
    myFile.print(txt);
    myFile.print(" : ");
    myFile.println(valeur);
    myFile.close();
    Serial.print("Ecriture sur SD : ");
    Serial.print(day(unix_epoch));
    Serial.print("/");
    Serial.print(month(unix_epoch));
    Serial.print("/");
    Serial.print(year(unix_epoch));
    Serial.print(" ");
    Serial.print(hour(unix_epoch)+1);
    Serial.print(":");
    Serial.print(minute(unix_epoch));
    Serial.print(" ");
    Serial.print(txt);
    Serial.print(" : ");
    Serial.println(valeur);
 *                                             L I R E   C O N F
void lireConf() {
  File myFile;
      String ligne = "";
      myFile = SD.open("config.ini", FILE_READ);
      while (myFile.available()) {
          char a = myFile.read();
          if (a == '\n') {
            Serial.println(ligne);
            String consigne = ligne.substring(0, ligne.indexOf(":")+1);
            String reponse = ligne.substring(ligne.indexOf(":")+1, ligne.indexOf(";"));
            if (consigne == "WIFI :") {
              reponse.toCharArray(bufferSsid, reponse.length() + 1);
              ssid=bufferSsid;
            if (consigne == "WIFI Mot de passe :") {
                reponse.toCharArray(bufferPass, reponse.length() + 1);
                pass=bufferPass;
            if (consigne == "Serveur de temps :") {
              //char buffer[reponse.length() + 1];
              reponse.toCharArray(bufferServeurTemps, reponse.length() + 1);
            if (consigne =="IP serveur :") {
                reponse.toCharArray(bufferIPServeur, reponse.length() + 1);
            if (consigne == "Raffraichissement HTML sec :") { RefresHTML = reponse.toInt(); }
            if (consigne == "Tempo :") { tempo = reponse.toInt(); }
            if (consigne == "[0] :") { valeurs[0][0] = reponse; }
            if (consigne == "[1] :") { valeurs[1][0] = reponse; }
            if (consigne == "[2] :") { valeurs[2][0] = reponse; }
            if (consigne == "[3] :") { valeurs[3][0] = reponse; }
            if (consigne == "[4] :") { valeurs[4][0] = reponse; }
            if (consigne == "[5] :") { valeurs[5][0] = reponse; }
            ligne = "";
            ligne += a;
     myFile.close();
 *                                             E C R I R E   C O N F
void envoyerConf() {
  SD.remove("config.ini");
  File myFile;
  myFile = SD.open("config.ini", FILE_WRITE);
  myFile.print("WIFI :");
  myFile.print(bufferSsid);
  myFile.println(";");
  myFile.print("WIFI Mot de passe :");
  myFile.print(bufferPass);
  myFile.print("IP serveur :");
  myFile.print(bufferIPServeur);
  myFile.print("Serveur de temps :");
  myFile.print(bufferServeurTemps);
  myFile.print("Raffraichissement HTML sec:");
  myFile.print(RefresHTML);
  myFile.print("Tempo :");
  myFile.print(tempo);
  for (byte i=0; i<6; i++) {
    myFile.print("[");myFile.print(i);myFile.print("]:");
    myFile.print(valeurs[i][0]);
  myFile.close();
 *                                         P A G E   W E B
void html() {
 // String lien = "http://" + wifiIP;
  client.println("Content-Type: text/html; charset=UTF-8");
  client.println("");
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<head>");
  client.println("<style>");
 // client.println("table, td, th {");
 // client.println("border: 1px solid black;");
 // client.println("}");
  client.println("#table2 {");
  client.println("border-collapse: collapse;");
  client.println("</style>");
  client.println("<html lang='fr'>");//<META HTTP-EQUIV=\'Refresh\' CONTENT=\'" + String(RefresHTML) + "; URL=' + wifiIP + '\'>");
  client.println("<title>Infos Maison</title>");
  client.println("</head>");
  client.println("<body style='background-color:#5DADE2;'>");
  client.println("<center>");
  client.println("<font size='7'>Configuration</font>");
  client.println("</center>");
  client.println("<font size='5'>");
  client.println("<br><br>");
  client.println("");
  client.println("<table>");
  for (byte n=0; n<6; n++) {
    client.println("    <tr>");
    client.println("      <td>");
    client.println("         " + valeurs[n][0]);
    client.println("      </td>");
    client.print(  "         <input type='text' id='name" + String(n) + "' value='" + valeurs[n][0] + "' ");
    if (valeurs[n][0]=="LIBR" || valeurs[n][0]=="libr") { client.println("disabled"); }
    //client.print(  "            ");
    client.println(" minlength='1' maxlength='4' size='6' onchange=\'noms()\'>");
    client.println("      <td  style='text-align:right'>");
    client.println("         " + valeurs[n][1] + " °C");
    client.println("      <td width='50'>");
    client.println("         <label class='switch'>Mesure activée : ");
    client.println("         <input type='checkbox' id='chk" + String(n) + "' value='" + String(n) + "'");
    if (valeurs[n][0]!="LIBR" && valeurs[n][0]!="libr") { client.println(" checked "); }
    client.println("         onclick=\'active("+ String(n) +")\'>");
    client.println("         </label>");
    client.println("    </tr>");
  client.println("</table>");
  client.println("");
  client.println("</br></br>");
  client.println("Fréquence d'enregistrement des températures :<br>");
  client.println("<table id='table2' width=50% style='border: 1px solid black; text-align:center'>");
  client.println("<tr>");
  client.println("<td style='border: 1px solid black'>Jour</td>");
  client.println("<td style='border: 1px solid black'>Heures</td>");
  client.println("<td style='border: 1px solid black'>Minutes</td>");
  client.println("</tr>");
  client.println("<td id='jourV' style='border: 1px solid black'>0</td>");
  client.println("<td id='heureV' style='border: 1px solid black'>0</td>");
  client.println("<td id='minuteV' style='border: 1px solid black'>0</td>");
  client.println("<td id='jourV' style='border: 1px solid black'><input id='Vj' type='range' style='width:90%' value='"+ String(j_) +"' max='6' min='0' step='1' onchange=\'duree()\'></td>");
  client.println("<td id='heureV' style='border: 1px solid black'><input id='Vh' type='range' style='width:90%' value='"+ String(h_) +"' max='23' min='0' step='1' onchange=\'duree()\'></td>");
  client.println("<td id='minuteV' style='border: 1px solid black'><input id='Vm' type='range' style='width:90%' value='"+ String(m_) +"' max='59' min='0' step='1' onchange=\'duree()\'></td>");
  client.println("Rafraichissement de la page (" + String(RefresHTML) + " secondes) [non activé]:<br>");
  client.println("<input id='refresh' type='range' style='width:50%' value='"+ String(RefresHTML) +"' max='600' min='10' step='1' disabled><br>");
  client.println("<table id='tableDonnees' width=75% style='border: 1px solid black; text-align:center'>");
  client.println("    <td style='border: 1px solid black'>serveur de temps</td>");
  client.println("    <td style='border: 1px solid black'>");
  client.println("         <input type='text' id='tmps' value='" + String(ServeurTemps) + "'  onchange=\'infoTemps()\'>");
  client.println("<td style='border: 1px solid black'>Wifi</td>");
  client.println("         <input type='text' id='ssid' value='" + String(ssid) + "'  onchange=\'infoSsid()\'>");
  client.println("<td style='border: 1px solid black'>Mot de passe</td>");
  client.println("         <input type='text' id='pass' value='" + String(pass) + "'  onchange=\'infoPass()\'>");
  client.println("<td style='border: 1px solid black'>Adresse IP serveur</td>");
  client.println("         <input type='text' id='server' value='" + String(IPServeur) + "'  onchange=\'infoServer()\'>");
  client.println("<input type='button' value='Efface toutes les données' onclick=\'efface()\'><br><br>");
  client.println("<input type='button' value='Lire les données' onclick=\'data()\'><br>");
//  client.println("<input type='button' value='Lire config.' onclick=\'config()\'><br>");
  client.println("<input type='button' value='Variables / configuration' onclick=\'variables()\'><br>");
  client.println("<input type='button' value='Graph' onclick=\'graph()\'><br>");
  client.println("</font>");
  client.println("<font size='1'>");
  client.println("<span style='float: right'>H. Deconchat 2022</span>");
  client.println("</body>");
  client.println("</html>");
  client.println("     <!-- §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§ -->");
  client.println("     <script type=\"text/javascript\">");
  client.println("                  var j = document.getElementById('Vj').value;");
  client.println("                  var h = document.getElementById('Vh').value;");
  client.println("                  var m = document.getElementById('Vm').value;");
  client.println("                  var x = (((j * 24) + h) * 60) + m;");
  client.println("                  document.getElementById('minuteV').innerHTML = m;");
  client.println("                  document.getElementById('jourV').innerHTML = j;");
  client.println("                  document.getElementById('heureV').innerHTML = h;");
  client.println("                  var txt = \'/TEMP='+x+'min\';");
  client.println("     <!-- -------------------------------------- -->");
  client.println("             function active(index)");
  client.println("               {");
  client.println("                  var c = document.getElementById('chk' + index).checked;");
  client.println("                  if (!c) {");
  client.println("                         document.getElementById('name' + index).value = 'libr';");
  client.println("                         document.getElementById('name' + index).disabled = true");
  client.println("                      } else {");
  client.println("                         document.getElementById('name' + index).value = 'acti';");
  client.println("                         document.getElementById('name' + index).disabled = false");
  client.println("                      };");
  client.println("                  noms()");
  client.println("               }");
  client.println("             function infoTemps()");
  client.println("                  var v = document.getElementById('tmps').value;");
  client.println("                  var txt = \'/SERVERTEMPS='+v+';\';");
  client.println("                  window.location.href=txt;");
  client.println("             function infoSsid()");
  client.println("                  var v = document.getElementById('ssid').value;");
  client.println("                  var txt = \'/SSID='+v+';\';");
  client.println("             function infoPass()");
  client.println("                  var v = document.getElementById('pass').value;");
  client.println("                  var txt = \'/PASS='+v+';\';");
  client.println("             function infoServer()");
  client.println("                  var v = document.getElementById('server').value;");
  client.println("                  var txt = \'/SERVER='+v+';\';");
  client.println("             function duree()");
  client.println("                  var x = ((((j * 24) + h) * 60) + m);");
  //client.println("                  document.getElementById('minuteV').innerHTML = x;");
  client.println("                  var txt = \'/TEMP='+j+'j'+h+'h'+m+'min\';");
  client.println("             function noms()");
  client.println("                  var tx = ''");
  client.println("                  for (let i=0; i<6; i++) {");
  client.println("                      tx += '[' + i + ']' + document.getElementById('name'+i).value + ';';");
  client.println("                  var txt = \'/NOMS='+ tx +'\';");
  client.println("             function efface()");
  client.println("                  window.location.href=\'/EFFACE=oui\';");
  client.println("             function data()");
  client.println("                  window.location.href=\'/DATA=oui\';");
  client.println("             function config()");
  client.println("                  window.location.href=\'/CONFIG=oui\';");
  client.println("             function variables()");
  client.println("                  window.location.href=\'/VARIABLES=oui\';");
  client.println("             function graph()");
  client.println("                  window.location.href=\'/GRAPH=oui\';");
  client.println("     </script>");
 *                                         P A G E   W E B   I I  (data)
void html2() {
  client.println("");
 // client.println("<META HTTP-EQUIV=\'Refresh\' CONTENT=\'" + String(RefresHTML) + "; URL=' + wifiIP + '\'>");
  client.println("<font size='7'>Températures enregistrées</font>");
  client.println("<br><input type='button' value='Page principale' onclick=\'retour()\'>");
  client.println("");
      File myFile;
      String ligne = "";
      myFile = SD.open("mesures.txt", FILE_READ);
          if (a == '\n') {
            //Serial.println(ligne);
            client.println(ligne);
            client.println("<br>");
            ligne = "";
            ligne += a;
      myFile.close();
  client.println("<input type='button' value='Page principale' onclick=\'retour()\'>");
  client.println("             function retour()");
  client.println("                  window.location.href=\'/RETOUR=oui\';");
 *                                         P A G E   W E B   I I I (config)
void html3() {
  client.println("");
  client.println("");
      File myFile;
      String ligne = "";
          if (a == '\n') {
            ligne = "";
            ligne += a;
      myFile.close();
 *                                         P A G E   W E B   I I I I (variables)
void html4() {
  client.println("");
  client.println("<font size='7'>Variables</font>");
  client.println("");
  client.println("WIFI : " + String(ssid) + "<br>");
  client.println("WIFI Mot de passe : " + String(pass) + "<br>");
  client.println("IP Serveur : " + String(IPServeur) + "<br>");
  client.println("Serveur de temps : " + String(ServeurTemps) + "<br>");
  client.println("Rafraichissement HTML sec : " + String(RefresHTML) + "<br>");
  client.println("Tempo : " + String(tempo) + "<br>");
  client.println("[0] : " + valeurs[0][0] + "<br>");
  client.println("[1] : " + valeurs[1][0] + "<br>");
  client.println("[2] : " + valeurs[2][0] + "<br>");
  client.println("[3] : " + valeurs[3][0] + "<br>");
  client.println("[4] : " + valeurs[4][0] + "<br>");
  client.println("[5] : " + valeurs[5][0] + "<br>");
  client.println("<font size='5'>Fichier de configuration</font><br>");
      File myFile;
      String ligne = "";
          if (a == '\n') {
            ligne = "";
            ligne += a;
      myFile.close();
void html5() {
    client.println("  <!DOCTYPE HTML>");
  client.println("  <html>");
  client.println("    <head>");
  client.println("      <style>");
  client.println("      #graphe {");
  client.println("        width: 100%;");
  client.println("        aspect-ratio : 9 / 4;");
  client.println("        border: 1px solid black;");
  client.println("        background-color: white;");
  client.println("        position:relative;");
  client.println("      .voie0 { ");
  client.println("        border-color: green;");
  client.println("      .voie1 { ");
  client.println("        border-color: blue;");
  client.println("      .cercle {");
  client.println("        transform: translate(-2px,-2px);");
  client.println("        width: 4px;");
  client.println("        height: 4px;");
  client.println("        border-radius: 20px;");
  client.println("        position: absolute;");
  client.println("        display: block;");
  client.println("        border-width: 1px;");
  client.println("        border-style: solid;");
  client.println("        background-color: border-color;");
  client.println("      .cercle:hover {");
  client.println("        transform: translate(-15px,-15px);");
  client.println("        -webkit-transform:scale(2.5); /* Safari et Chrome */");
  client.println("        -moz-transform:scale(2.5); /* Firefox */");
  client.println("        -ms-transform:scale(2.5); /* Internet Explorer 9 */");
  client.println("        -o-transform:scale(2.5); /* Opera */");
  client.println("        transform:scale(2.5);");
  client.println("      .horizontal {");
  client.println("        width: calc(100% - 70px);");
  client.println("        left: 35px;");
  client.println("        background: black;");
  client.println("      .vertical {");
  client.println("        width: 1px;");
  client.println("      .miniMax{");
  client.println("        width: 8px;");
  client.println("        border-width: 2px;");
  client.println("        border-style: solid none solid solid;");
  client.println("        transform: translate(-5px,0px);");
  client.println("      .texte {");
  client.println("      .trait {");
  client.println("        height: 1px;");
  client.println("        transform-origin: left top;");
  client.println("        border-style: dashed none none none;");
  client.println("        background: none;");
  client.println("      .verti {");
  client.println("        transform-origin: top left;");
  client.println("        transform:rotate(270deg);");
  client.println("        -ms-transform:rotate(270deg); /* Internet Explorer */");
  client.println("        -moz-transform:rotate(270deg); /* Firefox */");
  client.println("        -webkit-transform:rotate(270deg); /* Safari et Chrome */");
  client.println("        -o-transform:rotate(270deg); /* Opera */");
  client.println("      </style>");
  client.println("      <html lang='fr'>");
  client.println("      <title>Infos Maison</title>");
  client.println("    </head>");
  client.println("    <body id='graaphe' style='background-color:#5DADE2;'>");
  client.println("    <input type='button' value='Page principale' onclick=\'retour()\'>");
  client.println("    <div style='height: 10% width: 100%'>");
  client.println("      <center>");
  client.println("        <font size='7'>Graphique</font>");
  client.println("      </center>");
  client.println("    </div>");
  client.println("    <div id=graphe>");
  client.println("    </body>");
  client.println("  </html>");
  client.println("  <script type='text/javascript'>");
  client.println("        var datas0 = [];");
  client.println("    var datas1 = [];");
  client.println("    var datas2 = [];");
  client.println("    var datas3 = [];");
  client.println("    var datas4 = [];");
  client.println("    var datas5 = [];");
  client.println("    var datas6 = [];");
  client.println("    var datasX = [];");
  client.println("    var iiDebut;");
  client.println("    var yMax = -999;");
  client.println("    var yMin = 999;");
  client.println("    /* datas */   {");
  for (byte n = 0; n<6; n++) {
    if (valeurs[n][0]!="libr") {
        File myFile;
        String ligne = "";
            if (a == '\n') {
              byte voie = ligne.substring(1, ligne.indexOf("]")).toInt();
              String horo = ligne.substring(ligne.indexOf("]")+1, ligne.indexOf(" ("));
              unsigned int tmp = ligne.substring(ligne.indexOf("(")+1, ligne.indexOf(")")).toInt();
              String txt = ligne.substring(ligne.indexOf(")")+1, ligne.indexOf(" :"));
              int valeur = ligne.substring(ligne.indexOf(" : ")+3, 255).toInt();
              if (voie == n) {
                  client.println("        addPoint('" + String(n) + "', '" + horo + "', " + valeur/10 + ");");
              ligne = "";
              ligne += a;
        myFile.close();
  client.println("        // fin des datas");
  client.println("    affichesLesPoints(100,0);");
  client.println("function addPoint(n, x, y) {");
  client.println("    if (n == 0) { datas0.push([n,x,y]); }");
  client.println("    if (n == 1) { datas1.push([n,x,y]); }");
  client.println("    if (y > yMax) { yMax = y; }");
  client.println("    if (y < yMin) { yMin = y; }");
  client.println("    var date = strToDateUS(x);");
  client.println("    if (datasX.includes(date) == false ) { datasX.push(date); }       ");
  client.println("function strToDateUS(dtStr) {");
  client.println("    let dt = dtStr.split(' ');");
  client.println("    let dateParts = dt[0].split('/');");
  client.println("    return dateParts[2]+'/'+dateParts[1]+'/'+dateParts[0]+' '+dt[1];");
  client.println("function affichesLesPoints(ii0, ii1) {");
  client.println("  var eff = document.getElementsByClassName('efface');");
  client.println("  for (var i=eff.length-1 ; i>-1 ; i--) { eff[i].remove(); }");
  client.println("  if (ii0>ii1) {");
  client.println("    ii0 = 0;");
  client.println("    ii1 = datasX.length;");
  client.println("  yMax = -999;");
  client.println("  yMin = 999;");
  client.println("  miniMaxi(datas0, ii0, ii1);");
  client.println("  miniMaxi(datas1, ii0, ii1);");
  client.println("  if (yMin > 0) { yMin =0 ;}");
  client.println("  ligneHorizontal(0, 3);");
  client.println("  for (var y=yMin-9; y<yMax+9; y++) { if (y%10 == 0) { ligneHorizontal(y, 1); } }");
  client.println("  placeLesPoints(datas0, ii0, ii1);");
  client.println("  placeLesPoints(datas1, ii0, ii1);");
  client.println("function miniMaxi(datas, i0, i1) {");
  client.println("  for (var i = i0; i < i1; i++) {");
  client.println("    for (var ii = 0; ii < datas.length; ii++) {");
  client.println("      if (datasX[i] == strToDateUS(datas[ii][1])) {");
  client.println("        var y = datas[ii][2];");
  client.println("function placeLesPoints(datas, i0, i1) {");
  client.println("  var x0=-9999;");
  client.println("  var y0=0;");
  client.println("  var de;");
  client.println("  var a;");
  client.println("  var max = -1000;");
  client.println("  var min = 1000;");
  client.println("  var somme = 0;");
  client.println("  var total = yMax-yMin+10;");
  client.println("  var k = parseInt((i1-i0) / 50);");
  client.println("  if (k<1) { k=1; }");
  client.println("        a = datas[ii][2];");
  client.println("        if (a>max) { max = a; }");
  client.println("        if (a<min) { min = a; }");
  client.println("        somme += a;");
  client.println("        if (i%k == 0) {");
  client.println("          var moyenne = somme;");
  client.println("          if (i>0) { moyenne = somme/k; }");
  client.println("          var y = (80 - ((moyenne - yMin) * 80 / total));");
  client.println("          var x = 4 + (ii-i0) * 93 / ((i1-i0)+0);");
  client.println("          ligneVertical(x, (datas[ii][1]), ii);");
  client.println("          if (k>1 && min<max) { ");
  client.println("            miniMax(yEgal(min, yMin, total), yEgal(max, yMin, total), x, datas[ii][0], 'de '+ min + ' à ' + max);");
  client.println("          if (x0 != -9999) {            ");
  client.println("            trait(x0, y0, x, y, datas[ii][0], de, a);");
  client.println("          point(datas[ii][0], datas[i][1], moyenne, x, y);");
  client.println("          ");
  client.println("          x0 = x;");
  client.println("          y0 = y;");
  client.println("          de = a;");
  client.println("          max = -1000;");
  client.println("          min = 1000;");
  client.println("          somme = 0;");
  client.println("function yEgal(nb, yMin, total) { return (80 - ((nb - yMin) * 80 / total)); }");
  client.println("function point(voie, date, temp, x, y) {");
  client.println("  var point = document.createElement('div');");
  client.println("  point.id = 'Courbe ' + voie + ' le ' + strToDateUS(date);");
  client.println("  point.className = 'efface voie' + voie + ' cercle';");
  client.println("  point.title = 'Courbe ' + voie + ' le ' + date + ' Temp : ' + temp + '°C';");
  client.println("  point.style.top = y + '%';");
  client.println("  point.style.left = x + '%'");
  client.println("  document.getElementById('graphe').appendChild(point);");
  client.println("function trait(x0, y0, x1, y1, voie, de, a) {");
  client.println("  const oGraphe = document.getElementById('graphe');");
  client.println("  const H_GRAPH = oGraphe.offsetHeight;");
  client.println("  const W_GRAPH = oGraphe.offsetWidth;");
  client.println("  const RAPPORT_XY = W_GRAPH / H_GRAPH;");
  client.println("  var y = 0;");
  client.println("  var ligne = document.createElement('div');");
  client.println("  ligne.title = 'de ' + de + ' à ' + a + '°C';");
  client.println("  ligne.className = 'efface voie' + voie+ ' trait';");
  client.println("  ligne.style.left = x0 + '%';");
  client.println("  ligne.style.top = y0 + '%';");
  client.println("  var ab = x1-x0;");
  client.println("  var bc = y1-y0;");
  client.println("  if (y1<y0) { bc = y0-y1; }");
  client.println("  bc /=  RAPPORT_XY;");
  client.println("  var hypo = Math.sqrt(ab * ab + bc * bc);");
  client.println("  ligne.style.width = hypo + '%';");
  client.println("  var ang = Math.acos(ab / hypo);");
  client.println("  if (y0<y1) { ligne.style.transform = 'rotate('+ang+'rad)'; } ");
  client.println("    else { ligne.style.transform = 'rotate(-'+ang+'rad)'; }");
  client.println("  document.getElementById('graphe').appendChild(ligne);");
  client.println("} ");
  client.println("function ligneHorizontal(vvY, n) {");
  client.println("  var ligne = document.createElement('div')");
  client.println("  ligne.id = 'valeur' + vvY;");
  client.println("  ligne.className = 'efface horizontal';");
  client.println("  ligne.title = 'Y=' + vvY;");
  client.println("  var h = (80 - ((vvY - yMin) * 80 / total));");
  client.println("  ligne.style.top = h + '%';");
  client.println("  ligne.style.height = n + 'px';");
  client.println("  var txt = document.createElement('div');");
  client.println("  txt.innerText = vvY;");
  client.println("  txt.className = 'efface texte';");
  client.println("  document.getElementById('graphe').appendChild(txt);");
  client.println("  txt.style.top = h-2 + '%';");
  client.println("function miniMax(mini, maxi, x, voie, titre) {");
  client.println("  ligne.className = 'efface miniMax voie' + voie;");
  client.println("  ligne.style.top = maxi + '%';");
  client.println("  ligne.style.height = mini-maxi + '%';");
  client.println("  ligne.style.left = x + '%';");
  client.println("  ligne.title = titre;");
  client.println("function ligneVertical(vvX, date, ii) {");
  client.println("  ligne.id = 'date' + date;");
  client.println("  ligne.className = 'efface vertical';");
  client.println("  ligne.title = date;");
  client.println("  ligne.style.top = 1 + '%';");
  client.println("  ligne.style.height = '82%';");
  client.println("  ligne.style.left = vvX + '%';");
  client.println("  txt.innerText = date.split(' ')[0];");
  client.println("  txt.title = date;");
  client.println("  txt.className = 'efface texte verti';");
  client.println("  txt.style.top = 98 + '%';");
  client.println("  txt.style.left = vvX + '%';");
  client.println("  txt.onmousedown = function(){");
  client.println("        console.log(ii);");
  client.println("    iiDebut = ii;");
  client.println("  txt.onmouseup = function(){");
  client.println("        console.log(' ==> ' + ii);");
  client.println("    affichesLesPoints(iiDebut, ii);");
It seems that it is sending to the other arduino that blocks the program, I have to adjust the frequency of sending
The various tests carried out seem to show that it was the high frequency of sending packets to the other arduino.
Thanks for your help (knowing that the standby should be enabled)
