Tupran
1
I want to make a project that is connected to several Victron units by the VE.direct bus.
Some people has used ESP devices to connect one Victron unit but I want to connect with only one MCU for saving power consumption.
As I understand Arduino Nano 33 IoT has 6 serial ports and one is used for USB programming port.
Are the 5 other ports available for external devices?
Tupran
3
Thanks!
As I understand it, by a little tweeking more serial can be available. By Google search I see one port are used by Nina wire less modul.
So can the other four ports be used to serial interfaces by a little tweeking?
Sorry, I have no idea whether ports used as standard for other interfaces such as I2C can be used instead as a UART interface
system
Closed
5
