I am new here, started using samd21 based arduino nano 33 iot recently was changing a code intended for arduino uno/mega AVR MCU to work on samd21 based arduino nano but i am facing an issue with serial communiction. after i upload code i dont see any serial communication in serial monitor, any help will be appriciated.
#define N 160 //How many frequencies
float results[N]; //-Filtered result buffer
float freq[N]; //-Filtered result buffer
int sizeOfArray = N;
volatile unsigned int d;
delay(1000); // prevents usb driver crash on startup, do not omit this
while (!SERIAL) ; // Wait for serial terminal to open port before starting program
Serial.println("");
Serial.println("******************************");
Serial.println(" Program start ");
Serial.flush();
GCLK->GENCTRL.reg = GCLK_GENCTRL_IDC | // Improve duty cycle
GCLK_GENCTRL_GENEN | // Enable generic clock gen
GCLK_GENCTRL_SRC_DFLL48M | // Select 48MHz as source
GCLK_GENCTRL_ID(4); // Select GCLK4
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
// Set clock divider of 3 to generic clock generator 4
GCLK->GENDIV.reg = GCLK_GENDIV_DIV(3) | // Divide 48 MHz by 3 = 16Mhz
GCLK_GENDIV_ID(4); // Apply to GCLK4 4
// Enable GCLK4 and connect it to TCC1 and TCC1
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN | // Enable generic clock
GCLK_CLKCTRL_GEN_GCLK4 | // Select GCLK4
GCLK_CLKCTRL_ID_TCC0_TCC1; // Feed GCLK4 to TCC0/1
// Use "Normal PWM" (single-slope PWM): count up to PER, match on CC[n]
TCC1->WAVE.reg = TCC_WAVE_WAVEGEN_NPWM; // Select NPWM as waveform
while (TCC1->SYNCBUSY.bit.WAVE); // Wait for synchronization
// Configure PA18 (D10 on Arduino Zero) to be output
PORT->Group[PORTA].DIRSET.reg = PORT_PA18; // Set pin as output
PORT->Group[PORTA].OUTCLR.reg = PORT_PA18; // Set pin to low
// Enable the port multiplexer for PA18
PORT->Group[PORTA].PINCFG[18].reg |= PORT_PINCFG_PMUXEN;
// Connect TCC1 timer to PA18.
PORT->Group[PORTA].PMUX[9].reg = PORT_PMUX_PMUXE_F;
// Set the period (the number to count to (TOP) before resetting timer)
TCC1->PER.reg = 110;
while (TCC1->SYNCBUSY.bit.PER);
// Set PWM signal to output 50% duty cycle
TCC1->CC[2].reg = 55;
while (TCC1->SYNCBUSY.bit.CC2);
// Enable output (start PWM)
TCC1->CTRLA.reg |= (TCC_CTRLA_ENABLE);
while (TCC1->SYNCBUSY.bit.ENABLE); // Wait for synchronization
for(int i=0;i<N;i++) //-Preset results
results[i]=0; //-+
for(d=0;d<N;d++)
int v=analogRead(0); //-Read response signal
TCC1->CTRLA.reg &= ~TCC_CTRLA_ENABLE; // Disable TC
while (TCC1->SYNCBUSY.bit.ENABLE); // wait for sync
TCC1->CTRLA.reg = TC_CTRLA_SWRST; // Reset TCC1
while (TCC2->CTRLA.bit.SWRST); // Wait for completion
TCC1->PER.reg = d; // ICR1=d; Set the period (PER) register for a PWM period of 1s
while (TCC2->SYNCBUSY.bit.PER); // Wait for synchronization // |
TCC1->CC[0].reg = d/2; // OCR1A=d/2; Set the duty cycle to 50%
while (TCC2->SYNCBUSY.bit.CC0); // Wait for synchronization OCR1A=d/2; //-+
TCC1->CTRLA.reg |= (TCC_CTRLA_ENABLE); // Enable output
results[d]=results[d]*0.5+(float)(v)*0.5; //Filter results
freq[d] = d;
// plot(v,0); //-Display
// plot(results[d],1);
// delayMicroseconds(1);
// PlottArray(1,freq,results);
