Arduino Nano 33 IOT with HC05, cannot get to function
Hi all,
I am attempting to get my Nano 33 to search for bluetooth classic devices using the HC05 module, however I am getting stuck as the Nano doesn't use SoftwareSerial, and I am unable to get the device working.
Any advice to get this functioning, if it can at all?
Unlike the classic Nano, the Tx and Rx pins on pins 0 and 1 of the Nano 33 IOT are separate from USB Serial and are addressed as Serial1.
Both the Nano33 IOT and the HC05 will communicate on Serial1 at 3.3v so no voltage divider or level shifter is required.
Thank you!
How would I call it in the code however, I have a SoftwareSerial define BTserial, however I'm not sure how to substitute this in the code.
My aim is to create a code that simply counts how many classic bluetooth devices are found in 10 seconds, print that number and repeat. However, all the codes I've tried haven't been able to do this.
Serial1.begin(baudRate)
Serial1.( ) will replace BTserial( ).
Post your code if you need more assistance.
As in -- Don't Use SoftwareSerial.
I am a big novice so sorry if the questions are quite simple! I've posted below the code I am working with
Serial Serial1(0, 1); // RX | TX
char c = ' ';
void delayAndRead()
  delay(50);
  while(Serial1.available())
    c = Serial1.read();
  delay(800);
void initHC05ToInq()
    Serial1.println("AT+CMODE=1");// Enable connect to any device
    delayAndRead();
    Serial1.println("AT+ROLE=1");// Set to master in order to enable scanning
    delayAndRead();
    Serial1.println("AT+INQM=1,10,24");//RSSI, Max 10 devices, ~30s
    delayAndRead();
    Serial1.println("AT+CLASS=0");// Disable COD filter
    delayAndRead();
    Serial1.println("AT+INIT");// Init.
    delayAndRead();
    Serial1.begin(115200);
    // HC-05 default serial speed for AT mode is 38400
    Serial1.begin(38400);
    // Wait for hardware to initialize
    // Set correct states for inq
    initHC05ToInq();
    // Start inq
    initMessage();
    Serial1.println("AT+INQ");
char lineBuffer[100];
char subBuffer[30];
int index = 0;
int index2 = 0;
int total = 0;
bool capture = false;
String send = "";
void initMessage()
  send = "Bluetooth1;{\"state\":{\"reported\":{\"devices\":[";
    // Keep reading from HC-05 and send to Arduino Serial Monitor
    if (Serial1.available())
        // Read character and append into buffer
        c = Serial1.read();
        lineBuffer[index] = c;
        index++;
        // When line ends
        if(c=='\n')
          // Remove line end characters from buffer
          lineBuffer[index-1]=0;// \r\n
          // Reset buffer index for next line
          index = 0;
          if(lineBuffer[0] == 'O' && lineBuffer[1] == 'K')
            // Finish message
            send += "]}}}";
            // DEBUG / TODO actually send this message
            if(total > 0)
              Serial.println(send);
            // Restart INQ
            total = 0;
            initMessage();
            capture = false;
            index2 = 0;
            for(index = 0; index < 30; index++)
              if(!capture)
                if(lineBuffer[index]==':')
                  capture = true;
                subBuffer[index2] = lineBuffer[index];
                if(lineBuffer[index] == ',')
                  subBuffer[index2] = 0;
                index2++;
            index = 0;
            // Add this line buffer
            String str((char*)subBuffer);
            if(send.indexOf(str) <= 0)
              // If not first then add comma
              if(total > 0)
                send += ",";
              send += "\"";
              send += str;
              send += "\"";
              // Keep count
              total++;
I am now getting a bunch of errors! It is essentially the example code given from the HC05 library, which I think runs off the SoftwareSerial library...
I had the feeling you'd do that.
// Serial Serial1(0, 1); // RX | TX
Then you have --
Serial1.begin(115200); // TOO FAST
Serial1.begin(38400); // Not TWICE
Your first error message (with the changes I noted) --
'int index' redeclared as different kind of symbol
(That's not owing to having disposed SoftwareSerial.)
Compile error "redeclared as different kind of symbol" - Using Arduino / Programming Questions - Arduino Forum
Thank you! I've got it to run without issues, now I just need to get it to scan devices and count how many its found every 10 seconds!
That doesn't sound like "big novice" to me. (-:
Thank you for the help! Next problem though, there isn't anything printing to the serial monitor at all, the red LED is blinking quite quickly yet not displaying anything
On the HC-05? (That means that it's not paired.)
Maybe I've got this a bit wrong, I don't want to pair the HC05, I want it to only search for how many devices it detects and then count how many it can detect every x period
You are way off the beaten path with this project. I would suggest that you modify the program to mirror the AT commands and the responses to Serial in order to know more about what is going on.
I think the HC05 has two ways of entering AT mode, and not all commands are recognized in one of the modes. How do you put the HC05 into AT mode?
So yes, I worked out that the HC05 module I have is the v3 one, and so there are 2 AT Modes. I got it returning something the serial monitor now, and my phone can somewhat connect (Weirdly it doesn't connect by searching, but by automatically attempting to connect). I am now attempting to put it into the second AT mode as mentioned in the post below, though that isn't working as it doesn't return anything in the serial monitor,
Please post your code.
Right now, something very simple.
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  //Begin serial communication with Arduino and HC-05
  Serial.println("Initializing...");
  Serial.println("The device started, now you can pair it with bluetooth!");
  if(Serial.available())
    Serial1.write(Serial.read());//Forward what Serial received to Software Serial Port
  if(Serial1.available())
    Serial.write(Serial1.read());//Forward what Software Serial received to Serial Port
  delay(20);
So it returns AT nicely, and can change settings, but AT+INQ returns Error (1F), I managed to put it into the second AT mode, yet again it doesn't even register AT+INQ as anything
It has version 3, and I just can't get it to simply return how many devices it can detect
Is it giving a fast or slow flash?
Many others have had issues with V3 and certain AT commands.
I have it altenating, the slow speed allows some AT Commands, and the fast doesn't which is fine.
I think I have purchased a V2 (may just be a V3), but we will see, if not I will just call it quits and use the BLE from the nano which is already working! WIll update you Monday
