I'm crazed. I have an Arduino Nano33 Sense Rev2 board, and haven't been able to find the board in any of the libraries I've installed. I can only find the Arduino Nano33 BLE board, and I specifically need to use the sensors on the Sense board. Where, oh where, is the right library...??
THX! Steve in Delaware
Take a look at Nano 33 BLE Sense Rev2 Cheat Sheet
Hi Dozie. NOPE. I looked at the cheat sheet, followed the instructions and got to the same no-board-there point. I tried the web editor, and could only find the BLE board, not the Sense Rev2...! I have some experience working with the IDE, have downloaded libraries, installed libraries from zip file, and have a pretty good grasp of the basics. But no matter which approach I took I haven't been able to find the Arduino Nano33 BLE Sense Rev2 board. Just to be sure, the package my board came in reads: "ABX00070 NANO 33 BLE SENSE" with these numbers below the barcode: 144000100010078. How do I get this board online?? I've been over the same ground six times to no avail. Must be missing something, please guide me through. :~) SG
It's not clear if your issue is with which libraries to use for the sensors on that board, or with expecting to find a board selection for the Nano 33 BLE Sense in Tools>Board>Arduino Mbed OS Nano Boards.
There is not a defined variant for the Nano 33 BLE Sense in the core.
If you select the board as Arduino Nano 33 BLE and # include the library for the sensor you want to address, is there an issue?
Hey cattledog. Yes, door #2...! I keep expecting to find that board as a selection. OK, clears that up, thx. I'll try including the individual sensors' libraries.
Is it so that using the web editor, all libraries are available as I need them?
TIA SG
I don't use the web editor, so I don't know if the sensor libraries you need are available. This post gives you directions for adding a library if one of the 4000 libraries from the library manager available through the web editor is not what your sensor needs.
https://forum.arduino.cc/t/limited-library-access-using-web-editor/861419/2
Thx for the tip. Well...I couldnot get the IDE to recognize the board. Even though it claimed to see the board and port, when I uploaded BLINK, it responded that there was no board. Argh. Then I went through the web editor and all was fine. I even mode a copy of BLINK as 2000ms on/500 ms off, so I could be sure it was working. Baby steps. Ima proceed through the web now. Thx SG
