Depening on current going through the Schottky diode, it can drop up to 0.4V. I would not bypass the Schottky as it provides protection when you use both external 5V and USB at the same time.
Can you explain why it would matter in your setup?
Hi there,
Thanks for your reply.
First of all I was really curios : and secondly since I'm working with a display connect to this 5V from the Arduino pin, the low voltage make unreadable the display due to low contrast caused form a low voltage coming.
More than that, if my project do not require to connect 5v and a USB at the same time, Do you think I could bypass the Schottky?
WHY do you need it to be exactly 5V (It will probably NEVER be 5V)?
Your board is a controller, NOT a power supply. If you need 5V, the buy a 5V power converter, and use that as the power supply.
