Arduino Nano and ADXL345
Hello hopefully there is someone who can help,
I am trying to create a system with the Arduino nano v3.0 with ATmega328, that will take the values from 2 Accelerometers (adxl345's) and then work out the difference between the two x , y and z values given by the two chips .
then in a processing sketch create a graph that time on the X axis and G force differential on the Y with each plane being a different colour( x is green y is red, z is blue..
I have the following code so far,
//Add the SPI library so we can communicate with the ADXL345 sensor
#include <SPI.h>
//Assign the Chip Select signal to pin 10.
int CS=10;
//ADXL345 Register Addresses
#define	DEVID		0x00	//Device ID Register
#define THRESH_TAP	0x1D	//Tap Threshold
#define	OFSX		0x1E	//X-axis offset
#define	OFSY		0x1F	//Y-axis offset
#define	OFSZ		0x20	//Z-axis offset
#define	DURATION	0x21	//Tap Duration
#define	LATENT		0x22	//Tap latency
#define	WINDOW		0x23	//Tap window
#define	THRESH_ACT	0x24	//Activity Threshold
#define	THRESH_INACT	0x25	//Inactivity Threshold
#define	TIME_INACT	0x26	//Inactivity Time
#define	ACT_INACT_CTL	0x27	//Axis enable control for activity and inactivity detection
#define	THRESH_FF	0x28	//free-fall threshold
#define	TIME_FF		0x29	//Free-Fall Time
#define	TAP_AXES	0x2A	//Axis control for tap/double tap
#define ACT_TAP_STATUS	0x2B	//Source of tap/double tap
#define	BW_RATE		0x2C	//Data rate and power mode control
#define POWER_CTL	0x2D	//Power Control Register
#define	INT_ENABLE	0x2E	//Interrupt Enable Control
#define	INT_MAP		0x2F	//Interrupt Mapping Control
#define	INT_SOURCE	0x30	//Source of interrupts
#define	DATA_FORMAT	0x31	//Data format control
#define DATAX0		0x32	//X-Axis Data 0
#define DATAX1		0x33	//X-Axis Data 1
#define DATAY0		0x34	//Y-Axis Data 0
#define DATAY1		0x35	//Y-Axis Data 1
#define DATAZ0		0x36	//Z-Axis Data 0
#define DATAZ1		0x37	//Z-Axis Data 1
#define	FIFO_CTL	0x38	//FIFO control
#define	FIFO_STATUS	0x39	//FIFO status
//This buffer will hold values read from the ADXL345 registers.
char values[10];
char output[20];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
double xg, yg, zg;
char tapType=0;
void setup(){
  //Initiate an SPI communication instance.
  SPI.begin();
  //Configure the SPI connection for the ADXL345.
  SPI.setDataMode(SPI_MODE3);
  //Create a serial connection to display the data on the terminal.
  //Set up the Chip Select pin to be an output from the Arduino.
  pinMode(CS, OUTPUT);
  //Before communication starts, the Chip Select pin needs to be set high.
  digitalWrite(CS, HIGH);
  //Create an interrupt that will trigger when a tap is detected.
  attachInterrupt(0, tap, RISING);
  //Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
  writeRegister(DATA_FORMAT, 0x01);
  //Send the Tap and Double Tap Interrupts to INT1 pin
  writeRegister(INT_MAP, 0x9F);
  //Look for taps on the Z axis(01) only.
  writeRegister(TAP_AXES, 0x01);
  //Set the Tap Threshold to 3g
  writeRegister(THRESH_TAP, 0x38);
  //Set the Tap Duration that must be reached
  writeRegister(DURATION, 0xFF);
  //100ms Latency before the second tap can occur.
  writeRegister(LATENT, 0x50);
  writeRegister(WINDOW, 0xFF);
  //Enable the Single and Double Taps.
  writeRegister(INT_ENABLE, 0xE0);
  //Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
  writeRegister(POWER_CTL, 0x08);  //Measurement mode
  readRegister(INT_SOURCE, 1, values); //Clear the interrupts from the INT_SOURCE register.
void loop(){
  //Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
  //The results of the read operation will get stored to the values[] buffer.
  readRegister(DATAX0, 6, values);
  //The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
  //The X value is stored in values[0] and values[1].
  x = ((int)values[1]<<8)|(int)values[0];
  //The Y value is stored in values[2] and values[3].
  y = ((int)values[3]<<8)|(int)values[2];
  //The Z value is stored in values[4] and values[5].
  z = ((int)values[5]<<8)|(int)values[4];
  //Convert the accelerometer value to G's.
  //With 10 bits measuring over a +/-4g range we can find how to convert by using the equation:
  // Gs = Measurement Value * (G-range/(2^10)) or Gs = Measurement Value * (8/1024)
  xg = x * 0.0078;
  yg = y * 0.0078;
  zg = z * 0.0078;
      // here is where i want to get the  g reading for both accelerometers seperately so i can graph them
      Serial.println("Background");
      Serial.print(xg);
      Serial.print(" G,");
      Serial.print(yg);
      Serial.print(zg);
      Serial.println(" G");
        // then i want to check for TAP on each chip ( if both sense then do same as if only one is sensed
      if(tapType > 0)
        if(tapType == 1){
          Serial.println("SINGLE TAP");
          Serial.print("X=");
          Serial.print(xg);
          Serial.print(" G, Y= ");
          Serial.print(yg);
          Serial.print(" G, Z=  ");
          Serial.print(zg);
        else{
          Serial.println("DOUBLE TAP");
          Serial.print((float)xg,2);
          Serial.print((float)yg,2);
          Serial.print((float)zg,2);
        detachInterrupt(0);
        delay(10);
        tapType=0;
  delay(10);
//This function will write a value to a register on the ADXL345.
//Parameters:
//  char registerAddress - The register to write a value to
//  char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
  //Set Chip Select pin low to signal the beginning of an SPI packet.
  digitalWrite(CS, LOW);
  //Transfer the register address over SPI.
  SPI.transfer(registerAddress);
  //Transfer the desired register value over SPI.
  SPI.transfer(value);
  //Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
//  char registerAddress - The register addresse to start the read sequence from.
//  int numBytes - The number of registers that should be read.
//  char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values){
  //Since we're performing a read operation, the most significant bit of the register address should be set.
  char address = 0x80 | registerAddress;
  //If we're doing a multi-byte read, bit 6 needs to be set as well.
  if(numBytes > 1)address = address | 0x40;
  //Set the Chip select pin low to start an SPI packet.
  //Transfer the starting register address that needs to be read.
  SPI.transfer(address);
  //Continue to read registers until we've read the number specified, storing the results to the input buffer.
  for(int i=0; i<numBytes; i++){
    values[i] = SPI.transfer(0x00);
  //Set the Chips Select pin high to end the SPI packet.
void tap(void){
  //Clear the interrupts on the ADXL345
  if(values[0] & (1<<5))tapType=2;
  else tapType=1;;
this is for one chip only and i am unsure on how to advance on to getting a second chip to interface with the nano and get the values i need to the processing sketch so that i can graph them.
Any help would be appreciated as ive been lost for a few days now.
The code is the same for a second SPI device except it will have CS connected to a different I/O pin.
//Assign the Chip Select signals to pins 10 and 9.
const int CS1=10;
const int CS2=9;
johnwasser:
const int CS1=10;
const int CS2=9;
Thank you so much, also had a breakthrough on the graphing side aswell,
cant upload to arduino at the moment saying - serial port com3 not found. i have also noticed 1 of the adxl's is getting hot, not quite sure why that is yet. - Now solved *
so would i be right in thinking i now need to read the values from the registers from each chip so that
(x1, y1, z1) = dataX0;
(x2, y2, z2) = dataX1
then work out diffrence then save to a text file?
