Hello everyone,
i like to put 2 leds on this sketch ... one when it receives and one when transmit ... can anyone help me ?
#include <ELECHOUSE_CC1101_SRC_DRV.h>
#include <RCSwitch.h>
int pinRx; // int for Receive pin.
int pinTx; // int for Transmit pin.
RCSwitch mySwitch = RCSwitch();
int buttonPin; // for button pin.
int buttonState = 0; // button state
int ccSetRx = 0; // reset state for Receive
int long value = 5393; // int to save value
int bits = 24; // int to save bit number
int prot = 1; // int to save Protocol number
int puls = 320; // int to save pulse length
pinRx = 0; pinTx = 6; // for Arduino! Receiver on interrupt 0 => that is pin #2. Transmit on pin 6.
buttonPin = 4; // set button on pin D4.
if (ELECHOUSE_cc1101.getCC1101()){ // Check the CC1101 Spi connection.
Serial.println("Connection OK");
}else{
Serial.println("Connection Error");
//CC1101 Settings: (Settings with "//" are optional!)
ELECHOUSE_cc1101.Init(); // must be set to initialize the cc1101!
//ELECHOUSE_cc1101.setRxBW(812.50); // Set the Receive Bandwidth in kHz. Value from 58.03 to 812.50. Default is 812.50 kHz.
//ELECHOUSE_cc1101.setPA(10); // set TxPower. The following settings are possible depending on the frequency band. (-30 -20 -15 -10 -6 0 5 7 10 11 12) Default is max!
ELECHOUSE_cc1101.setMHZ(433.92); // Here you can set your basic frequency. The lib calculates the frequency automatically (default = 433.92).The cc1101 can: 300-348 MHZ, 387-464MHZ and 779-928MHZ. Read More info from datasheet.
pinMode(buttonPin, INPUT); // set pin4 as input
buttonState = digitalRead(buttonPin); // read digital pin and save the state to int
if (buttonState == HIGH) { // the button is pressed. Set transmit on.
ccSetRx = 0; // set resetstate to 0 for next reinit to Recive
ELECHOUSE_cc1101.SetTx(); // set Transmit on
mySwitch.disableReceive(); // Receiver off
mySwitch.enableTransmit(pinTx); // Transmit on
mySwitch.setProtocol(prot); // send Received Protocol
mySwitch.setPulseLength(puls);// send Received Delay
mySwitch.send(value, bits); // send Received value/bits
Serial.print("Transmit ");
Serial.print( value );
Serial.print(" / ");
Serial.print( bits );
Serial.print("bit ");
Serial.print("Protocol: ");
Serial.print( prot );
Serial.print(" Delay: ");
Serial.println( puls );
if (buttonState == LOW && ccSetRx == 0){ //the button is not pressed. set cc1101 to Receive.
ELECHOUSE_cc1101.SetRx(); // set Receive on
mySwitch.disableTransmit(); // set Transmit off
mySwitch.enableReceive(pinRx); // Receiver on
ccSetRx = 1;
if (buttonState == LOW && ccSetRx == 1) { //the button is not pressed and set receive is finish. Receive values.
if (mySwitch.available()){
Serial.print("Received ");
Serial.print( mySwitch.getReceivedValue() );
Serial.print( mySwitch.getReceivedBitlength() );
Serial.print( mySwitch.getReceivedProtocol() );
Serial.println( mySwitch.getReceivedDelay() );
value = mySwitch.getReceivedValue(); // save received Value
bits = mySwitch.getReceivedBitlength(); // save received Bitlength
prot = mySwitch.getReceivedProtocol(); // save received Protocol
puls = mySwitch.getReceivedDelay(); // save received pulse length
mySwitch.resetAvailable();
