Hello,
I used arduino Nano and GPS ( NEO-6M) to get position of air plane RC but I never get Position.
I don't understand, could you help me please.
My code and the result below.
#include <SoftwareSerial.h>
// The serial connection to the GPS module
SoftwareSerial ss(4, 3);
void setup(){
ss.begin(9600);
void loop(){
while (ss.available() > 0){
// get the byte data from the GPS
byte gpsData = ss.read();
Serial.write(gpsData);
$GPRMC,,V,,,,,,,,,,N*53
$GPVTG,,,,,,,,,N*30
$GPGGA,,,,,,0,00,99.99,,,,,,*48
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
$GPGSV,4,1,15,01,,,25,02,,,27,03,,,26,04,,,26*7E
$GPGSV,4,2,15,06,,,25,07,,,25,11,,,26,14,,,25*7C
$GPGSV,4,3,15,23,,,26,24,,,26,25,,,28,28,,,24*7C
$GPGSV,4,4,15,33,,,29,37,,,30,48,,,31*7F
$GPGLL,,,,,,V,N*64
Code with telemetrty:
#include <iBUSTelemetry.h> //https://github.com/adis1313/iBUSTelemetry-Arduino
#include <Wire.h>
#include <TinyGPS++.h>
#include <SPI.h>
TinyGPSPlus gps;
#define UPDATE_INTERVAL 500
iBUSTelemetry telemetry(9); // arduino pin pour donnes iBUS
uint32_t prevMillis = 0; // neessaire pour updateValues()
float maxspeed = 0, speed1 = 0;
int maxhigh = 0, high1 = 0;
int maxsatelite = 0, satelite1 = 0;
float meters ;
float voltage = 0.0;
delay(50000);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);// carte SD absente
Serial.println(""); Serial.println("Demarrage acquisition ibus"); // Ecrit dans ce fichier
Serial.println(""); Serial.println("date heure latitude longitude altitude vitesse");
Wire.begin();
telemetry.begin();
// definition capteurs
telemetry.addSensor(IBUS_MEAS_TYPE_EXTV); //batterie
telemetry.addSensor(IBUS_MEAS_TYPE_SPE); //vitesse km/h
//telemetry.addSensor(IBUS_MEAS_TYPE_ALT); //altitude
//telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LAT); // latitude
//telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LON); // longitde
telemetry.addSensor( IBUS_MEAS_TYPE_VERTICAL_SPEED ); // utilisé pour altitude
telemetry.addSensor( IBUS_MEAS_TYPE_GROUND_SPEED );// utilisé pour latitude
telemetry.addSensor( IBUS_MEAS_TYPE_GPS_DIST );// utilisé pour longitde
telemetry.addSensor( IBUS_MEAS_TYPE_ARMED );// utilisé pour vitesse max
updateValues();
telemetry.run();
void updateValues()
// lecture donnes Gps et allumage LED si OK
if (Serial.available()) {
digitalWrite(13, LOW);//donnes Gps OK
gps.encode(Serial.read());
float meters = (gps.altitude.meters());
float airSpeed = (gps.speed.kmph());
// definition vitesse max
speed1 = (gps.speed.kmph());
if ( speed1 > maxspeed) {
maxspeed = speed1;
// recuperation date et heure du GPS pour datalogging
String Temps = String(gps.time.hour() + 1) + (":") + (gps.time.minute()) + (":") + (gps.time.second());
String Date = String(gps.date.day()) + ("/") + (gps.date.month()) + ("/") + (gps.date.year());
// Temporisation
uint32_t currMillis = millis();
if (currMillis - prevMillis >= UPDATE_INTERVAL) { // Code in the middle of these brackets will be performed every 500ms.
prevMillis = currMillis;
// affichage donnes capteur sur radiocommande
telemetry.setSensorValue(1, voltage * 100 );
telemetry.setSensorValue(2, speed1 );
telemetry.setSensorValue(3, gps.altitude.meters()); // altitude
telemetry.setSensorValue(4, gps.location.lat()); //latitude
telemetry.setSensorValue(5, gps.location.lng()) ; // longitude
telemetry.setSensorValue(6, maxspeed);
