Hello, I am a magician and puppeteer and have been making animatronics using SSC32 and Visual Show Automation for a long time. I have recently fallen in love with the arduino and have been using nanos to make various magic props.
I am trying to use an nano with this expansion shield to make a cheap ssc32
https://www.ebay.com/itm/133296906208?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
to animate servos and send digital ON/OFF signal from a nano. I found this code that makes the nano act as a Servo Serial Controller and it works! However, I am also trying to replicate the digital ON/OFF feature. My question is how can I alter the code so that some of the servos are instead a digital output.
Additionally, the code limits the servo to 135 degrees. How do I widen the range to 180?
Thank you so much for your help.
`// Serial Servo
// by Paul H. Dietz, 4/22/2014
// Allows an Arduino UNO to act like a Scott Edwards Mini Serial Servo Controller.
// Data Format:
// 9600 baud, 8-N-1
// Sync byte (255), Servo Num (2-13), Postion (0-254)
// Position to us:
// 6 * Position + 738
// 0 -> 738us, 254 -> 2262us
// This code is in the public domain. Use at your own risk.
#include <Servo.h>
byte ServoNum, ServoPos;
// Byte count for input
byte inCNT=0;
// create servo objects
Servo servo2, servo3, servo4, servo5, servo6, servo7, servo8, servo9, servo10, servo11, servo12, servo13;
// Initialize serial:
// Initialize Servos
servo2.attach(2);
servo3.attach(3);
servo4.attach(4);
servo5.attach(5);
servo6.attach(6);
servo7.attach(7);
servo8.attach(8);
servo9.attach(9);
servo10.attach(10);
servo11.attach(11);
servo12.attach(12);
servo13.attach(13);
/* Wait for data, then process
inCNT keeps track of current state:
0 – Waiting for sync byte
1 – Sync byte received
2 – Sync byte and ServoNum received
while (Serial.available()) {
// get the new byte:
byte inByte = Serial.read();
if (inByte == 255){
// Sync found
inCNT = 1;
else {
if (inCNT == 1) {
ServoNum = inByte;
inCNT = 2;
else {
if (inCNT == 2) {
ServoPos = inByte;
setServo();
inCNT = 0;
else {
inCNT = 0;
void setServo() {
switch (ServoNum) {
case 2:
servo2.writeMicroseconds((int)ServoPos6+738);
case 3:
servo3.writeMicroseconds((int)ServoPos6+738);
case 4:
servo4.writeMicroseconds((int)ServoPos6+738);
case 5:
servo5.writeMicroseconds((int)ServoPos6+738);
case 6:
servo6.writeMicroseconds((int)ServoPos6+738);
case 7:
servo7.writeMicroseconds((int)ServoPos6+738);
case 8:
servo8.writeMicroseconds((int)ServoPos6+738);
case 9:
servo9.writeMicroseconds((int)ServoPos6+738);
case 10:
servo10.writeMicroseconds((int)ServoPos6+738);
case 11:
servo11.writeMicroseconds((int)ServoPos6+738);
case 12:
servo12.writeMicroseconds((int)ServoPos6+738);
case 13:
servo13.writeMicroseconds((int)ServoPos6+738);
