Arduino nano as Trustmaster warthog slew mod
Welcome
I am currently working on a project that should enable me to improve my Thrustmaster Warthog joystick.
I found a project on instructables.com that I would like to do with Arduino Nano.
Link to the project worthdog mini joystick.
During compilation, unfortunately, I encounter a problem and I would ask for help, possibly directing to a solution.
> #include "Wire.h"
> void setup() {
>   Wire.begin(0x41);                // join i2c bus with address 0x41
>   Wire.onReceive(receiveEvent);    // I2C events
>   Wire.onRequest(requestEvent);
> volatile byte i2c_reg = 0;  //stores last byte transmitted
> volatile bool flag = 0;     //flag to set after y val sent
> char x_pos = 0;  //stores x and y vals to be sent
> char y_pos = 0;
> void loop() {
>   char temp_x = char(map(analogRead(3), 1023, 0, -128, 127));  //scales analog inputs to correct size
>   char temp_y = char(map(analogRead(4), 0, 1023, -128, 127));
>   if (flag) {
>     noInterrupts();
>     flag = 0;
>     x_pos = temp_x;
>     y_pos = temp_y;
>     interrupts();
> void requestEvent() {
>   switch (i2c_reg) {
>     case 0x10:
>       Wire.write(x_pos); //x val
>       break;
>     case 0x11:
>       Wire.write(y_pos); //y val
>       flag = 1;
>       break;
>     case 0x0F: //Ctrl 1 regester
>       Wire.write(0b11110001);
>       break;
> void receiveEvent() {
>   while (Wire.available()) {
>     i2c_reg = Wire.read();
the error that pops up is:
In function 'void setup ()':*
5:30: warning: invalid conversion from 'void () ()' to 'void () (int)' [-fpermissive]*
Wire.onReceive (receiveEvent); // I2C events*
Wire.h: 76: 10: note: initializing argument 1 of 'void TwoWire :: onReceive (void () (int))'
void onReceive (void () (int));
Thanks in advance for the hints.
Regards Arkadiusz
Where did you see the word "error"?
Uh-oh.
You have the point: its warning :slight_smile:
is it possible to correct the code? Will this warning affect the operation of the program?
