My Arduino Nano is not working. My first code is not uploaded. it will be Stuck in Uploading...
And I change Processor to ATmega328P (Old Bootloader). And It worked fine. But after I upload it 2 times, It got the same Error. I have not changed anything. Please help me.
Here is the Error code:
Using board 'nano' from platform in folder: C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\sketch\sketch_may7a.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\sketch\sketch_may7a.ino.cpp" -o "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\uzaif\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\sketch\sketch_may7a.ino.cpp" -o "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\sketch\sketch_may7a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\uzaif\AppData\Local\Temp\arduino-core-cache\core_arduino_avr_nano_cpu_atmega328old_acd96ab1ed57f3aa8aa67240776041b9.a
Linking everything together...
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.elf" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB\sketch\sketch_may7a.ino.cpp.o" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/..\arduino-core-cache\core_arduino_avr_nano_cpu_atmega328old_acd96ab1ed57f3aa8aa67240776041b9.a" "-LC:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB" -lm
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.elf" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.eep"
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.elf" "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.hex"
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.elf"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Compilation complete.
"C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b57600 -D "-Uflash:w:C:\Users\uzaif\AppData\Local\Temp\arduino-sketch-AED53722DFC1202272A715AEADC6F1FB/sketch_may7a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\uzaif\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7d
avrdude done. Thank you.
Upload error: Error: 2 UNKNOWN: uploading error: uploading error: exit status 1
