I have an Arduino Nano Rev 3.0 which has worked well for some time.
After uploading a program yesterday, the Nano cannot be bothered to upload anything new, the IDE returns avrdude: stk500_getsync(): not in sync: resp=0x00.
When I connect the Nano to a serial port and read it's output, it still executes the program that I uploaded last and provides some date over the serial port. Reset button just starts the program in flash over and over.
I have reinstalled the USB and serial drivers on my Mac, no different results.
I have an Arduino Uno giving the same error. It was working well all this while (about 3 months.) I mounted an Arduino compatible L298N shield that drives a couple of DC motors.
Using Port : \.\COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
When I try to upload a sketch, the TX led flickers but there is absolutely no response from the RX led. What could be the issue? Is there a chance that the board got short-circuited?
Any help appreciated, thanks a lot.
I had the exact problem last week with a new ATMega 328 chip. Turns out the baud rate in the new chip that I swapped in was different than my config file. Loopback worked, but avrdude didn't. I futzed around with baud rates until I found one that matched what the new chip was programmed to read at. Good luck.
