Arduino nano BLE sense use gesture (APDS9960) and other I2C device with Wire lib
Got an Arduino nano BLE sense, using the light sensor.
This code working :
#include <Arduino_APDS9960.h>
    APDS.begin();
    if (APDS.colorAvailable()){
        int r, g, b, alpha;
        APDS.readColor(r, g, b, alpha);
        Serial.print("alpha: ");
        Serial.println(alpha);
    delay(100);
I want to send alpha value to an other Arduino by I2C protocol.
After connecting the other board and verify the communication is valid, I get this code:
#include <Wire.h>
    APDS.begin();
    Wire.begin(); // Begin Wire as master ...
        int r, g, b, alpha;
        Wire.beginTransmission(10);
        Wire.write(alpha);
        Wire.endTransmission();
    delay(100);
With the above code, the condition APDS.colorAvailable() is never True.
I don't know why ... Probably because I instantiate the Wire library ?
The APDS9960 library already initializes the I2C peripheral. Have a look into the Arduino_APDS9960 library. The two file are not very complicated. You can find it in the libraries folder inside your projects folder.
What happens when you comment this line: Wire.begin(); // Begin Wire as master ... ?
If that does not work you could change the order in setup() and see what happens then.
